Product
SonicWALL SRA 1600 Base Appliance with 5 User License
Quicklinx: 8TVGWS00 Mfr#: 01-SSC-6594
Dell SonicWALL Secure Remote Access (SRA) series solutions are simple to deploy and even easier to use for a fraction of the price of most other products.
Remote access has never been so simple to deploy and use. Mobile employees only require a standard browser to log into a customizable portal that provides access to email, files, Web applications and internal Web sites. For even more powerful capabilities such as secure access to any resource on the corporate network including servers and local applications, the appliances transparently push a downloadable thin client (NetExtender) to the user's desktop or laptop.
  • Seamless integration behind virtually any firewall
    Seamless integration behind virtually any firewall enables organizations to leverage the existing network infrastructure.
  • Clientless connectivity
    Clientless connectivity removes the need for a pre-installed VPN client, thus freeing administrators from a tedious and costly task.
  • NetExtender technology
    NetExtender technology enables network level access to resources, services and applications.
  • A personalized Web portal
    A personalized Web portal displays only those resources that are available to the user based on company policy.
  • Remote support using SonicWall Virtual Assist
    Remote support using SonicWall Virtual Assist enables technicians to provide secure on-demand assistance to customers while leveraging the existing infrastructure.
  • Unified policy
    Unified policy displays granular bookmarks and policies in one centralized page, streamlining configuration, troubleshooting and administrative overhead.
SonicWall SRA 1600 - VPN gateway
VPN gateway
External
RAM
1 GB
Flash Memory
1 GB
Ports Qty
2
Concurrent users: 5 , Maximum number of users: 50
AC 100/230 V (50/60 Hz)
43.8 cm x 25.73 cm x 4.45 cm
4.3 kg
VPN gateway
43.8 cm
25.73 cm
4.45 cm
4.3 kg
Processor / Memory / Storage
RAM
1 GB
Flash Memory
1 GB
External
Ports Qty
2
Remote Management Protocol
Telnet, HTTP, HTTPS, SSH
Hardware encryption, VPN support, Syslog support, IPv6 support
Encryption Algorithm
Triple DES, RSA, MDC2, ARCFOUR, SHA-1, TLS 1.0, SSL 3.0, 256-bit AES
Authentication Method
RADIUS, LDAP, Active Directory, VASCO token authentication
2 x 1000Base-T - RJ-45 , 1 x management - RJ-45 , 2 x USB - Type A
MTBF
18.3 years
FCC Class A certified, UL, TUV GS, C-Tick, BSMI, cUL, NOM, VCCI Class A ITE, CB, KCC, ANATEL, ICES Class A
Internal power supply
47 Watt
5 - 95% (non-condensing)
8TVG C2G 2m USB 2.0 A/B Cable - Black In Stock £3.82
8TVG C2G 5m USB 2.0 A/B Cable - Black In Stock £4.96
8TVG C2G 4-Port USB 2.0 Aluminum Hub In Stock £14.78
8TVG C2G 12m USB 2.0 A/A Active Extension Cable In Stock £16.17
8TVG C2G USB Superbooster Extender Kit In Stock £36.55
8TVG C2G Trulink® USB to Gigabit Ethernet Adapter In Stock £22.60
8TVG C2G USB to HDMI Adapter with Audio Up To 1080p In Stock £42.30
