Product
SonicWALL SonicPoint ACe Radio Access Point with SonicWALL 802.3at Gigabit PoE Injector
Quicklinx: CMFBWS00 Mfr#: 01-SSC-0883
  • IEEE 802.11n
Take advantage of superior wireless network performance without sacrificing security. Dell SonicPoint ACe wireless access points use 802.11ac technology to provide high-speed wireless connectivity. Easily set up and manage all your SonicPoints from a single location.
  • Superior wireless performance and range
    With support for the 802.11ac standard, the SonicPoint ACe can achieve a data rate of up to 1.3 Gbps while maintaining a higher performance level at greater ranges.
  • Enhanced signal quality and reliability
    The 802.11ac wireless standard operates in the 5 GHz frequency band, which is less prone to signal interference, thus enhancing signal quality. Dual radios, six external antennas and 3x3 MIMO result in more reliable wireless coverage.
  • Flexible deployment options
    SonicPoint ACe can receive power from Ethernet and Gigabit Ethernet (GbE) cabling through an 802.3at Power over Ethernet (PoE) injector, as well as directly through an AC adapter. As a plenum rated access point, the SonicPoint ACe can be safely installed in air-handling spaces, such as in or above suspended ceilings.
  • Discreet deployment options
    With dimmable LEDs (excluding power), SonicPoint ACe fits seamlessly into environments that need discreet wireless coverage.
SonicWall SonicPoint ACe - radio access point - with 1 year Dynamic Support 24X7 - with SonicWALL 802.3at Gigabit PoE Injector
Radio access point
Bundled Services
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Virtual access points: 8 , Maximum number of clients: 256
Power Over Ethernet (PoE) Supported
PoE+
17.5 cm x 17.5 cm x 3.8 cm
530 g
Bundled with
Radio access point
Bundled Services
17.5 cm
17.5 cm
3.8 cm
530 g
Bundled with
External
Wireless
Data Transfer Rate
1.3 Gbps
Spread Spectrum Method
OFDM, DSSS
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Power, test mode, WLAN, LAN
Auto-sensing per device, VPN support, DFS support, firmware upgradable, wall mountable, Wireless Intrusion Detection System (WIDS), Access Control List (ACL) support, Wireless Guest Services, Samba support, Multiple SSID support, 3T3R MIMO technology, plenum-rated, ceiling mountable, Wireless Intrusion Prevention System (WIPS), Captive Portal, Virtual Access Points (VAP), Reassembly-Free Deep Packet Inspection (RFDPI)
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, 152-bit WEP, SSL, TKIP, WPA, WPA2, WPA-Enterprise, WPA2-Enterprise
Authentication Method
RADIUS, Active Directory, eDirectory, Transparent Active Directory Authentication (Single Sign-on)
IEEE 802.3i, IEEE 802.11b, IEEE 802.11a, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11n, IEEE 802.3at, IEEE 802.3e, IEEE 802.11ac
Aerial
Antenna
External detachable
Antenna Qty
6
1 x 1000Base-T (PoE+) - RJ-45 , 1 x 1000Base-T - RJ-45 , 1 x console - RJ-45 , 1 x USB 2.0 - Type A
UL, TUV GS, BSMI, cUL, CB, UL 2043, FCC, RoHS, ICES Class B, WEEE, ANATEL, TELEC, VCCI Class B, NCC, RCM, MSIP, CoC
PoE+
External power adapter
15.2 Watt
Extended service agreement - replacement - 1 year - shipment - response time: next day , Technical support - phone consulting - 1 year , Technical support - web support - 1 year , New releases update - 1 year
10 - 95% (non-condensing)
