Secure Upgrade Plus offers an upgrade path from current Dell SonicWALL products, as well as a trade-in path from competitors' products. This offer recognizes the past investments that customers have made and helps them maintain optimal security by letting them easily and affordably replace their existing security appliances.
Customers who purchase the complete set of subscription services and support when upgrading a Dell SonicWALL product or trading-in a competitive product can save up to 50% on the total annual cost of that solution, compared to the cost of buying the hardware separately and renewing services each year.
Full-featured, advanced security
Deliver full-featured security that combines intrusion prevention, gateway anti-virus, anti-spyware, content filtering and anti-spam services, with intuitive, easy-to-use SonicWall TZ Series firewalls. -
Broad, flexible remote access
Provide mobile users with native VPN remote access clients for Apple iOS, Google Android, Windows, Mac OS and Linux, via your small business firewall. This unique client also supports SonicWall Clean VPN, which enables the firewall to decontaminate threats from VPN traffic. -
Easy to deploy, all-in-one solution
Enjoy the convenience and affordability of deploying your TZ Series appliance as a SonicWall TotalSecure solution. This combines the hardware and all the services needed for comprehensive network protection from viruses, spyware, worms, Trojans, key loggers and more - before they enter your network - and without the complexity of building your own security package. -
Secure wireless connectivity
Encrypt wireless traffic with secure Internet access over high-speed 802.11n wireless to ensure integrity while, providing secure, password-protected Internet access. The TZ Series also Provies 3G wireless WAN and analog modem connectivity as primary or secondary connections.
- SonicWall TZ400 - security appliance - with 2 years SonicWALL Comprehensive Gateway Security Suite - Secure Upgrade Plus
- Security appliance
- Bundled Services
- 2 years SonicWALL Comprehensive Gateway Security Suite
- Form Factor
- External
- Data Link Protocol
- Performance
- Firewall throughput: 1.3 Gbps , Application throughput: 1.2 Gbps , IPS throughput: 900 Mbps , Anti-malware throughput: 600 Mbps , TLS/SSL inspection and decryption throughput: 180 Mbps , VPN throughput (IPSec): 900 Mbps , Connection rate: 6000 connections per second , Threat prevention throughput: 600 Mbps
- Capacity
- Virtual interfaces (VLANs): 50 , SSL VPN licences: 2 (maximum 100) , VPN tunnels (site-to-site): 20 , IPSec VPN clients: 2 (maximum 25) , SPI connections: 150000 , DPI connections: 125000 , Authenticated users (internal database): 150 , Single Sign-On (SSO) users: 500 , Manageable access points: 16 , DPI SSL connections: 25000
- VoIP Protocols
- SIP, H.323 v3, H.323 v4, H.323 v1, H.323 v2, H.323 v5
- Power
- AC 100-240 V (50/60 Hz)
- Pricing Type
- SonicWALL Secure Upgrade Plus Program
- 19 cm x 13.4 cm x 3.5 cm
- 730 g
- Bundled Services
- 19 cm
- 13.4 cm
- 3.5 cm
- 730 g
- Form Factor
- External
- Connectivity Technology
- Wired
- TCP/IP, PPTP, UDP/IP, L2TP, ICMP/IP, IPSec, PPPoE, DHCP
- Routing Protocol
- OSPF, RIP-1, RIP-2, BGP, static IP routing, policy-based routing (PBR)
- Remote Management Protocol
- SNMP 2, SNMP 3, HTTP, HTTPS, CLI
- Performance
- Capacity
- Firewall protection, VPN support, PAT support, VLAN support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, port mirroring, IPv6 support, antivirus analysis, Intrusion Prevention System (IPS), URL filtering, Deep Packet Inspection (DPI), DDos attack prevention, Wi-Fi Multimedia (WMM) support, anti-spam protection, anti-malware protection, Quality of Service (QoS), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), DHCP server, bandwidth control, Common Access Card (CAC) reader support, anti-spyware protection, DHCP relay, 3G/4G USB Dongle Support, NetFlow, DiffServ Code Point (DSCP) support, Single Sign-On (SSO) support, anti-virus protection, keyword filtering
- Encryption Algorithm
- DES, Triple DES, MD5, SHA-1, 128-bit AES, 192-bit AES, 256-bit AES
- Authentication Method
- RADIUS, LDAP, internal user database, Active Directory, XAUTH authentication
IP Telephony
- VoIP Protocols
- 6 x 1000Base-T - RJ-45 , 1 x 1000Base-T - RJ-45 (WAN) , 1 x USB 3.0 - Type A , 1 x console - RJ-45
- MTBF
- 54 years
- FCC Class A certified, UL, TUV GS, C-Tick, BSMI, ICSA Firewall certified, cUL, ICSA Antivirus, CB, FIPS 140-2 Level 2, EMC, RoHS, WEEE, ANATEL, GOST-R, REACH, ICES Class A, KCC Class A, VPNC certified, LVD, IPv6 Ready, VCCI Class A, MSIP, CoC, UC APL
- Pricing Type
- Power Device
- External power adapter
- Voltage Required
- 9.2 Watt
- Power Provided
- 24 Watt
- OS Provided
- SonicOS
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
