Dell SonicWALL NSA 3500 is a next generation United Threat Management firewall, utilizing a breakthrough multi-core hardware design with 4 cores and 6 Gigabit Ethernet interfaces to deliver real-time internal and external network protection without compromising network performance for corporate, branch office and distributed environments. The NSA 3500 combines high-speed intrusion prevention, file and content inspection and powerful application firewall capabilities with an extensive array of advanced networking and configuration flexibility features in an accessible, affordable platform that is easy to deploy and manage in a wide variety of environments.
Next-generation firewall security
A suite of tools, including intrusion prevention, gateway anti-virus, and anti-spyware plus application intelligence and control, offer granular control through application blocking, bandwidth management and more. Additional security and connectivity capabilities such as IPSec VPN, SSL VPN, content filtering, anti-spam and enforced client anti-virus make the NSA series a comprehensive and powerful all-in-one security solution. -
Multi-core architecture
Single-core and ASIC processors may have been sufficient for the design of traditional stateful firewalls. But NSA series appliances go above and beyond, with a multi-core design to help ensure that the deep packet inspection provided by the SonicWall Next-Generation Firewall can scale with your expanding organization. As many as eight cores spread the network load evenly and protect against extreme performance degradation often present in other technologies when exposed to heavy traffic conditions and malicious content. -
Deep packet inspection technology
Proprietary SonicWall RFDPI technology offers extremely high scalability and performance suitable for even the most demanding environments. RFDPI scans traffic on every port, on every protocol and in any direction to provide ultimate visibility and control. The unique design of the RFDPI engine allows it to inspect every byte of a connection - and up to hundreds of thousands of simultaneous connections - in order to categorize application traffic and protect against internal and external threats at both the application and network layer. -
Lowered complexity and cost
Along with superior power efficiency, SonicWall NSA series appliances lower the total cost of ownership by reducing complexity and the time necessary to configure, deploy and maintain security solutions. An intuitive GUI and powerful set-up wizards make it easy to quickly set up and fine-tune network policies, application rules, VPN connections and more.
- SonicWall NSa 3500 - security appliance - with 1 year TotalSecure
- Security appliance
- Bundled Services
- 1 year TotalSecure
- Form Factor
- External - 1U
- RAM
- 512 MB
- Ports Qty
- 6
- Data Link Protocol
- Performance
- Firewall throughput: 1 Gbps , VPN throughput (3DES/AES): 650 Mbps , Intrusion prevention throughput: 220 Mbps , Gateway anti-virus throughput: 310 Mbps , Firewall throughput (IMIX): 440 Mbps , Connection rate: 5000 connections per second
- Capacity
- VPN client licences: 250 , VPN tunnels (site-to-site): 800 , Nodes: unlimited , Connection / user qty: 128000 , Authenticated users (internal database): 500
- VoIP Protocols
- SIP, H.323 v3, H.323 v4, H.323 v1, H.323 v2
- Included Accessories
- 512 MB CompactFlash Card
- OS Required
- Microsoft Windows 2000, Microsoft Windows Vista / XP
- Power
- AC 120/230 V (50/60 Hz)
- 43.2 cm x 33.7 cm x 4.4 cm
- 5.1 kg
- Bundled Services
- Height (Rack Units)
- 1U
- 43.2 cm
- 33.7 cm
- 4.4 cm
- 5.1 kg
Processor / Memory / Storage
- RAM
- 512 MB
- Form Factor
- External
- Ports Qty
- 6
- Connectivity Technology
- Wired
- Data Transfer Rate
- 1 Gbps
- TCP/IP, PPTP, UDP/IP, L2TP, ICMP/IP, IPSec, PPPoE, DHCP
- Routing Protocol
- OSPF, RIP-1, RIP-2, static IP routing
- Remote Management Protocol
- SNMP 2, HTTP, HTTPS
- Performance
- Capacity
- Firewall protection, DHCP support, load balancing, Syslog support, DoS attack prevention, dynamic DNS server, antivirus analysis, High Availability, Intrusion Prevention System (IPS), Stateful Failover, anti-spam protection, Quality of Service (QoS), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T)
- Encryption Algorithm
- DES, Triple DES, MD5, IKE, SHA-1, PKI, 128-bit AES, 192-bit AES, 256-bit AES
- Authentication Method
- Secure Shell (SSH), RADIUS, X.509 certificates, LDAP, internal user database, Active Directory
- IEEE 802.1Q, X.509
IP Telephony
- VoIP Protocols
- 6 x 1000Base-T - RJ-45 , 1 x management , 2 x USB
- FCC Class A certified, UL, TUV, VCCI, BSMI, cUL, ICES-003, CB, CCC, PSB, RoHS
- Power Device
- Internal power supply
- Voltage Required
- 64 Watt
- Power Provided
- 180 Watt
- OS Provided
- SonicOS Enhanced
- Software Included
- SonicWALL ViewPoint
- OS Required
- Virus definitions update - 1 year , E-mail database update - 1 year , Intrusion definitions update - 1 year
- 5 °C
- 40 °C
- 10 - 90%
