SonicWALL NSA 2650 Secure Upgrade Plus - Advanced Edition 3YR
Quicklinx: D668WS00 Mfr#: 01-SSC-1997
SonicWall Secure Upgrade Plus Advanced Edition for NSA 2650 - Subscription licence (3 years) - 1 appliance
  • Next-generation firewall security
    A suite of tools, including intrusion prevention, gateway anti-virus, and anti-spyware plus application intelligence and control, offer granular control through application blocking, bandwidth management and more. Additional security and connectivity capabilities such as IPSec VPN, SSL VPN, content filtering, anti-spam and enforced client anti-virus make the NSA series a comprehensive and powerful all-in-one security solution.
  • Multi-core architecture
    Single-core and ASIC processors may have been sufficient for the design of traditional stateful firewalls. But NSA series appliances go above and beyond, with a multi-core design to help ensure that the deep packet inspection provided by the SonicWall Next-Generation Firewall can scale with your expanding organization. As many as eight cores spread the network load evenly and protect against extreme performance degradation often present in other technologies when exposed to heavy traffic conditions and malicious content.
  • Deep packet inspection technology
    Proprietary SonicWall RFDPI technology offers extremely high scalability and performance suitable for even the most demanding environments. RFDPI scans traffic on every port, on every protocol and in any direction to provide ultimate visibility and control. The unique design of the RFDPI engine allows it to inspect every byte of a connection - and up to hundreds of thousands of simultaneous connections - in order to categorize application traffic and protect against internal and external threats at both the application and network layer.
  • Lowered complexity and cost
    Along with superior power efficiency, SonicWall NSA series appliances lower the total cost of ownership by reducing complexity and the time necessary to configure, deploy and maintain security solutions. An intuitive GUI and powerful set-up wizards make it easy to quickly set up and fine-tune network policies, application rules, VPN connections and more.
SonicWall NSa 2650 - Advanced Edition - security appliance - Secure Upgrade Plus
Security appliance
Rack-mountable - 1U
Gigabit Ethernet, 2.5 Gigabit Ethernet
Performance
Firewall throughput: 3 Gbps , Full Deep Packet Inspection (DPI) throughput: 600 Mbps , Application throughput: 1.4 Gbps , IPS throughput: 1.4 Gbps , Anti-malware throughput: 600 Mbps , Firewall throughput (IMIX): 700 Mbps , SSL throughput: 250 Mbps , VPN throughput: 1.3 Gbps , Connection rate: 14000 connections per second
SPI connections: 1000000 , DPI connections: 500000 , Maximum number of access points: 48 , VPN tunnels (site-to-site): 1000 , IPSec VPN connections: 50 , SSL VPN users: 2 , Virtual interfaces (VLANs): 256 , Single Sign-On (SSO) users: 40000
VoIP Protocols
SIP, H.323 v3, H.323 v4, H.323 v1, H.323 v2, H.323 v5
Power Redundancy
Optional
Pricing Type
SonicWALL Secure Upgrade Plus Program (3 years option)
43 cm x 32.5 cm x 4.5 cm
5.2 kg
Security appliance
Height (Rack Units)
1U
43 cm
32.5 cm
4.5 cm
5.2 kg
Rack-mountable
Wired
Network / Transport Protocol
TCP/IP, PPTP, UDP/IP, L2TP, ICMP/IP, IPSec, PPPoE, DHCP
Routing Protocol
OSPF, RIP-1, RIP-2, BGP, static IP routing, policy-based routing (PBR)
Remote Management Protocol
SNMP 2, SNMP 3, HTTP, HTTPS, CLI
Performance
NAT support, VPN support, load balancing, Stateful Packet Inspection (SPI), DoS attack prevention, Intrusion Prevention System (IPS), URL filtering, Deep Packet Inspection (DPI), DDos attack prevention, Stateful switchover (SSO), anti-spam protection, anti-malware protection, Quality of Service (QoS), RADIUS support, DHCP server, DNS proxy, DHCP relay, NetFlow, IPFIX, 2 fans
Encryption Algorithm
DES, Triple DES, MD5, SHA-1, 128-bit AES, 192-bit AES, 256-bit AES
Authentication Method
RADIUS, internal user database, XAUTH authentication
IEEE 802.3, IEEE 802.1p
IP Telephony
VoIP Protocols
IP Telephony Features
VoIP gatekeeper support, VoIP outbound bandwidth management
Expansion Slots
1 (total) / 1 (free) x expansion slot
12 x 1000Base-T - RJ-45 , 2 x USB - Type A , 1 x 1000Base-T (management) - RJ-45 , 1 x management - RJ-45 , 4 x 2.5Gb Ethernet - SFP (mini-GBIC) , 4 x 2.5Gb Ethernet - RJ-45
MTBF
18.5 years
FCC Class A certified, UL, TUV GS, C-Tick, BSMI, cUL, CB, EMC, RoHS, WEEE, ANATEL, REACH, KCC Class A, LVD, VCCI Class A, MSIP Class A, CoC
Pricing Type
Internal power supply
Installed Qty
1
Max Supported Qty
2
Power Redundancy
Optional
37.2 Watt
Power Provided
120 Watt
OS Provided
SonicOS 6.5.1
Shipping Weight
7.7 kg
10 - 90% (non-condensing)
