SonicWALL Network Security Appliance 2600
Quicklinx: 94NMWS00 Mfr#: 01-SSC-4275
The Dell SonicWALL Network Security Appliance (NSA) series combines the patented Dell SonicWALL Reassembly Free Deep Packet Inspection (RFDPI) engine with a powerful and massively scalable multi-core architecture to deliver intrusion prevention, gateway anti-virus, gateway anti-spyware, and application intelligence and control for businesses of all sizes. By integrating automated and dynamic security capabilities into a single platform, the NSA series provides comprehensive next-generation firewall protection without compromising performance.
Along with superior power efficiency, Dell SonicWALL NSA series appliances lower the total cost of ownership by reducing complexity and the time necessary to configure, deploy and maintain security solutions. An intuitive GUI and powerful set-up wizards make it easy to quickly set up and fine-tune network policies, application rules, VPN connections and more.
  • Next-generation firewall security
    A suite of tools, including intrusion prevention, gateway anti-virus, and anti-spyware plus application intelligence and control, offer granular control through application blocking, bandwidth management and more. Additional security and connectivity capabilities such as IPSec VPN, SSL VPN, content filtering, anti-spam and enforced client anti-virus make the NSA series a comprehensive and powerful all-in-one security solution.
  • Multi-core architecture
    Single-core and ASIC processors may have been sufficient for the design of traditional stateful firewalls. But NSA series appliances go above and beyond, with a multi-core design to help ensure that the deep packet inspection provided by the SonicWall Next-Generation Firewall can scale with your expanding organization. As many as eight cores spread the network load evenly and protect against extreme performance degradation often present in other technologies when exposed to heavy traffic conditions and malicious content.
  • Deep packet inspection technology
    Proprietary SonicWall RFDPI technology offers extremely high scalability and performance suitable for even the most demanding environments. RFDPI scans traffic on every port, on every protocol and in any direction to provide ultimate visibility and control. The unique design of the RFDPI engine allows it to inspect every byte of a connection - and up to hundreds of thousands of simultaneous connections - in order to categorize application traffic and protect against internal and external threats at both the application and network layer.
  • Lowered complexity and cost
    Along with superior power efficiency, SonicWall NSA series appliances lower the total cost of ownership by reducing complexity and the time necessary to configure, deploy and maintain security solutions. An intuitive GUI and powerful set-up wizards make it easy to quickly set up and fine-tune network policies, application rules, VPN connections and more.
SonicWall NSa 2600 - security appliance - with 3 years SonicWALL Comprehensive Gateway Security Suite
Security appliance
Bundled Services
Rack-mountable - 1U
RAM
2 GB
Gigabit Ethernet
Performance
Firewall throughput: 1.9 Gbps , Full Deep Packet Inspection (DPI) throughput: 300 Mbps , Application throughput: 700 Mbps , IPS throughput: 700 Mbps , Anti-malware throughput: 400 Mbps , Firewall throughput (IMIX): 600 Mbps , SSL throughput: 200 Mbps , VPN throughput: 1.1 Gbps , Connection rate: 15000 connections per second
SPI connections: 225000 , DPI connections: 125000 , Maximum number of access points: 32 , VPN tunnels (site-to-site): 75 , IPSec VPN connections: 10 , SSL VPN users: 2 , Virtual interfaces (VLANs): 50
VoIP Protocols
SIP, H.323 v3, H.323 v4, H.323 v1, H.323 v2, H.323 v5
Pricing Type
SonicWALL Secure Upgrade Plus Program
43 cm x 26 cm x 4.5 cm
4.6 kg
Security appliance
Bundled Services
Height (Rack Units)
1U
43 cm
26 cm
4.5 cm
4.6 kg
Processor / Memory / Storage
RAM
2 GB
Rack-mountable
Wired
Gigabit Ethernet
Network / Transport Protocol
TCP/IP, PPTP, UDP/IP, L2TP, ICMP/IP, PPPoE, DHCP
Routing Protocol
OSPF, RIP-1, RIP-2, BGP, static IP routing, policy-based routing (PBR)
Remote Management Protocol
SNMP 2, SNMP 3, CLI
Performance
NAT support, VPN support, load balancing, Stateful Packet Inspection (SPI), DoS attack prevention, antivirus analysis, Intrusion Prevention System (IPS), URL filtering, Deep Packet Inspection (DPI), DDos attack prevention, anti-spam protection, anti-malware protection, Quality of Service (QoS), RADIUS support, DHCP server, bandwidth control, DHCP relay, NetFlow, IPFIX
Encryption Algorithm
DES, Triple DES, MD5, SHA-1, 128-bit AES, 192-bit AES, 256-bit AES
Authentication Method
RADIUS, internal user database, Active Directory, XAUTH authentication
IEEE 802.1p
IP Telephony
VoIP Protocols
IP Telephony Features
VoIP gatekeeper support, VoIP outbound bandwidth management
Expansion Slots
1 (total) / 1 (free) x expansion slot
8 x 1000Base-T - RJ-45 , 2 x USB - Type A , 1 x 1000Base-T (management) - RJ-45 , 1 x management - RJ-45
MTBF
20.2 years
FCC Class A certified, UL, TUV GS, VCCI, C-Tick, BSMI, ICSA Firewall certified, cUL, NOM, ICSA Antivirus, CB, RoHS, FIPS 140-2, KCC, WEEE, ANATEL, VPNC certified
Pricing Type
Internal power supply
Installed Qty
1
Max Supported Qty
1
49.4 Watt
Power Provided
200 Watt
OS Provided
SonicOS
10 - 90% (non-condensing)
94NM C2G 5m USB 2.0 A/B Cable - Black In Stock £5.09
