Expand, control and protect your network. A fast connection to your business, school, remote office or retail site is only half the story; you also need to be able to securely manage it. The TZ500 gives you enterprise-grade protection to stop cyberattacks as you expand and control your network. The TZ500 offers a no-compromise approach to securing growing networks. For distributed enterprises with remote offices, all TZ products can be managed by the central office using a larger SonicWALL firewall and GMS.
High-performance security engine
All SonicWall firewalls use patented Reassembly-Free Deep Packet Inspection to examine traffic simultaneously across all ports without introducing latency to the network, enabling businesses to realize increased productivity gains. -
Intrusion prevention
A tightly integrated intrusion prevention engine protects against a comprehensive array of application-layer exploits that target both servers and client machines on the network. -
Advanced IPSec and SSL VPN
Flexible connectivity options provide easy-to-use, secure, high-speed office-to-office and client-to-office remote access. With IPSec VPN, users can also connect with a SonicWall Global VPN Client. -
Gateway anti-virus and anti-spyware
By blocking Trojans, viruses, key loggers and other malware at the gateway, SonicWall Gateway Anti-Virus and Anti-Spyware provides the first layer of defense. -
Streamlined GUI and advanced management
Intuitive set-up wizards and a powerful web interface ease deployment, simplify configuration, and streamline management to reduce administration time and costs. -
Content/URL filtering
Organizations and educational institutions can easily enforce their acceptable-use policies and protect against inappropriate, illegal and dangerous web content through content and URL filtering. -
Wireless network security
The SonicPoint Series, featuring the performance and signal quality of 802.11ac, is ideal for businesses, schools, stores and branch offices looking to build a high-speed wireless network. SonicPoints integrate seamlessly with SonicWall next-generation firewalls to create a secure wireless solution that protects wireless traffic from harmful threats.
- SonicWall TZ500 - security appliance - with 2 years SonicWALL Comprehensive Gateway Security Suite - Secure Upgrade Plus
- Security appliance
- Bundled Services
- 2 years SonicWALL Comprehensive Gateway Security Suite
- Form Factor
- External
- Data Link Protocol
- Performance
- Firewall throughput: 1.4 Gbps , Application throughput: 1.3 Gbps , IPS throughput: 1 Gbps , Anti-malware throughput: 700 Mbps , TLS/SSL inspection and decryption throughput: 225 Mbps , VPN throughput (IPSec): 1 Gbps , Connection rate: 8000 connections per second , Threat prevention throughput: 700 Mbps
- Capacity
- Virtual interfaces (VLANs): 50 , SSL VPN licences: 2 (maximum 150) , VPN tunnels (site-to-site): 25 , IPSec VPN clients: 2 (maximum 25) , SPI connections: 150000 , DPI connections: 125000 , Authenticated users (internal database): 250 , Single Sign-On (SSO) users: 500 , Manageable access points: 16 , DPI SSL connections: 25000
- VoIP Protocols
- SIP, H.323 v3, H.323 v4, H.323 v1, H.323 v2, H.323 v5
- Power
- AC 100-240 V (50/60 Hz)
- Pricing Type
- SonicWALL Secure Upgrade Plus Program
- 22.5 cm x 15 cm x 3.5 cm
- 915 g
- Bundled Services
- 22.5 cm
- 15 cm
- 3.5 cm
- 915 g
- Form Factor
- External
- Connectivity Technology
- Wired
- TCP/IP, PPTP, UDP/IP, L2TP, ICMP/IP, IPSec, PPPoE, DHCP
- Routing Protocol
- OSPF, RIP-1, RIP-2, BGP, static IP routing, policy-based routing (PBR)
- Remote Management Protocol
- SNMP 2, SNMP 3, HTTP, HTTPS, CLI
- Performance
- Capacity
- Firewall protection, VPN support, PAT support, VLAN support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, port mirroring, IPv6 support, antivirus analysis, Intrusion Prevention System (IPS), URL filtering, deep inspection, DDos attack prevention, Wi-Fi Multimedia (WMM) support, anti-spam protection, anti-malware protection, Quality of Service (QoS), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), DHCP server, bandwidth control, Common Access Card (CAC) reader support, anti-spyware protection, DHCP relay, 3G/4G USB Dongle Support, NetFlow, DiffServ Code Point (DSCP) support, Single Sign-On (SSO) support, anti-virus protection, keyword filtering
- Encryption Algorithm
- DES, Triple DES, MD5, SHA-1, 128-bit AES, 192-bit AES, 256-bit AES
- Authentication Method
- RADIUS, LDAP, internal user database, Active Directory, XAUTH authentication
IP Telephony
- VoIP Protocols
- 7 x 1000Base-T - RJ-45 , 1 x 1000Base-T - RJ-45 (WAN) , 2 x USB 3.0 - Type A , 1 x console - RJ-45
- MTBF
- 40.8 years
- FCC Class A certified, UL, TUV GS, C-Tick, BSMI, ICSA Firewall certified, cUL, ICSA Antivirus, CB, FIPS 140-2 Level 2, EMC, RoHS, WEEE, ANATEL, GOST-R, REACH, ICES Class A, KCC Class A, VPNC certified, LVD, IPv6 Ready, VCCI Class A, MSIP, CoC, UC APL
- Pricing Type
- Power Device
- External power adapter
- Voltage Required
- 13.4 Watt
- Power Provided
- 36 Watt
- OS Provided
- SonicOS
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
