Wall mount for Somfy Protect Security Camera A discreet and elegant wall mount to hang your Somfy Security Camera up high, right on your wall.
What's in the box?
- Cover
- 2 screws + 2 pins for any surface
- 6.56" USB extension
- 15 double-sided adhesives
- Somfy camera mount
- Product Type
- Camera mount
- Placing / Mounting
- Wall mountable
- 7 cm x 3.83 cm x 6.5 cm
- 90 g
- Product Type
- Camera mount
- Wall mountable
- 7 cm
- 3.83 cm
- 6.5 cm
- 90 g
