Somfy Thermostatic Valve IO
Quicklinx: FM3ZWS00 Mfr#: 1870508
Type: Smart radiator valve
Hurry, only 2 left in stock!
£66.66 ex VAT
£79.99 inc VAT
Using the Somfy Thermostatic Radiator Valve you can have the right temperature in every room. Simply change the desired temperature on the valve or using the Somfy TaHoma.
  • Save Energy - only heat selected rooms
  • Optimize radiator control - smart placement of the temperature sensors secures accurate temperature measuring
  • Quiet yet powerful - the motor in the radiator valve is designed for optimal sound levels
  • Timer function - set each radiator individually according to your schedule
Operate manually or from Somfy TaHoma
Operable from Somfy app when combined with: TaHoma
NOTE: remote io or TaHoma not included. The screen will be upside down on UK radiators with the valve pointing vertically
Somfy Thermostatic Radiator Valve - smart radiator valve
Functions
Control heating systems
Power Source
Wireless
Frequency Band
868.25 - 868.95 Mhz
5.5 cm x 8.7 cm x 4.8 cm
Functions
Power Source
Wireless
Frequency Band
868.25 - 868.95 Mhz
Battery Required
2 x AA type
IP20
5.5 cm
8.7 cm
4.8 cm
160 g
50 °C
Brand: Somfy
Price Range Ex VAT: 50 - 100
