Somfy Outdoor Siren
Quicklinx: DMSTWS00 Mfr#: 2401491A
Type: Siren
Compatible With: Alexa, IFTTT, Google Assistant, Siri + 1 more
21 in stock
£108.33 ex VAT
£129.99 inc VAT
In the event of a detection, this outdoor siren emits a loud noise and bright flash to warn neighbors and prevent break-ins before they occur.
Somfy Protect Outdoor Siren - siren
Siren
Environment
Outdoor
Power Source
Wireless
Siren Sound Level
112 dB
22 cm x 22 cm x 5.5 cm
Siren
Environment
Outdoor
Power Source
Wireless
Max Range Open Space
200 m
Siren Sound Level
112 dB
D type
Battery Included
Required Qty
4
Alkaline
Battery Lifetime
2 years
IP43
22 cm
22 cm
5.5 cm
1.2 kg
-10 °C
45 °C
Type: Siren
Compatible With: IFTTT
Compatible With: Siri
Compatible With: Nest
Brand: Somfy
Stock Status: In stock
