Somfy Outdoor Camera Duo Pack - Grey
Quicklinx: FZ4RWS00 Mfr#: 1870472
The Somfy Outdoor Security Camera lets you scare burglars off with smart motion detection and a siren. The camera also comes with a smart activation function. When you get back home, the system will recognize you and switch itself off, and if you go out again, you'll get a reminder via the app on your smartphone to re-activate the camera. That's convenience for you!
As soon as the camera detects movement, the siren will go off and you'll immediately receive a push message on your smartphone. You can watch live, check the recorded images of 30 seconds and download those images for free.
Somfy Outdoor Camera - Duo Pack - network surveillance camera
Packaged Quantity
2 (specifications are for single item)
Network surveillance camera
Audio Support
Yes: built-in speaker, built-in microphone
Camera Mount Type
Wall mount
Wireless
15 cm
8.5 cm
15 cm
512 g
Camera
Colour - Day&Night - fixed - outdoor - weatherproof
Max Digital Video Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
Digital Zoom
8
Infrared LEDs
Infrared Distance
8 m
Frame Rate (max)
30 frames per second
Motion Detection Technology, reset button, High Dynamic Range (HDR), WPA, WPA2, built-in siren (110 dB)
Lens Construction
Horizontal Field of View (degree)
130
Network Interface
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0
Wall mount kit, allen wrench, 2 screws, reset tool
Plug and Play, AES-256
Anthracite grey
Power Requirements
AC 120/230 V
Internet of Things (IoT)
Platform
Somfy TaHoma
Compatible Application
IFTTT App
Intelligent Assistant
Google Assistant, Alexa
Limited warranty - 5 years
-20 °C
50 °C
