Somfy Outdoor Camera - Anthracite
Quicklinx: DWQVWS00 Mfr#: 2401563A
Colours:
£207.50 ex VAT
£249.00 inc VAT
Somfy’s smart outdoor camera - the smartest form of security
The thought of someone breaking into your home, prowling around your house, looking for valuables, perish the thought! What you really want is for the thieves or burglars to just keep off your property.
The camera also comes with a smart activation function. When you get back home, the system will recognise you and switch itself off, and if you go out again, you’ll get a reminder via the app on your smartphone to re-activate the camera. That’s convenience for you!
The outdoor camera with a built-in siren
Somfy Outdoor Camera is the most deterrent outdoor camera on the market, with a 110 dB built-in siren and the option to link it to an outdoor lighting system.
The Somfy outdoor camera forms part of the complete Somfy Plug and Play security products range and is compatible with Smart Home systems, such as Works With Nest, IFTTT, Amazon Alexa and Google.
Features:
  • Scare burglars off with smart motion detection and a siren
  • Full HD camera with night vision
  • Powerful siren (110 dB)
  • Talk to intruders via the built-in speaker
  • Motion detection: immediately starts recording when motion is detected
  • Image storage in the cloud
  • Connect via powersupply or external lighting
  • Compatible with known Smart Home systems
Somfy Outdoor Camera - network surveillance camera
Network surveillance camera - fixed - outdoor - weatherproof
Audio
Yes: built-in speaker, built-in microphone
Camera Mount Type
Wall mount
14.725 cm x 8.5 cm x 15.08 cm
512 g
Anthracite grey
Wireless
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Frame Rate (max)
30 frames per second
Motion Detection
Video Modes
1080p
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0
Voltage
AC 120/230 V
Motion Detection Technology, reset button, High Dynamic Range (HDR), built-in siren
Environmental Parameters (operating)
-20 °C - 50 °C
Audio Support
Camera Mount Type
Wall mount
Wireless
14.725 cm
8.5 cm
15.08 cm
512 g
Camera
Colour - Day&Night - fixed - outdoor - weatherproof
Max Digital Video Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
Digital Zoom
8
Infrared LEDs
Infrared Distance
8 m
Frame Rate (max)
Lens Construction
Horizontal Field of View (degree)
130
Network Interface
Wall mount kit, allen wrench, 2 screws, reset tool
AES-256, IP54
Anthracite grey
Power Requirements
AC 120/230 V
Internet of Things (IoT)
Platform
Nest, IFTTT, Somfy TaHoma
Intelligent Assistant Compatible
Google Assistant, Alexa
-20 °C
50 °C
Resources
The following resources are available for the Somfy Outdoor Camera - Anthracite
Brand: Somfy
Price Range Ex VAT: 150 - 300
