Somfy’s smart outdoor camera - the smartest form of security
The thought of someone breaking into your home, prowling around your house, looking for valuables, perish the thought! What you really want is for the thieves or burglars to just keep off your property.
The camera also comes with a smart activation function. When you get back home, the system will recognise you and switch itself off, and if you go out again, you’ll get a reminder via the app on your smartphone to re-activate the camera. That’s convenience for you!
The outdoor camera with a built-in siren
Somfy Outdoor Camera is the most deterrent outdoor camera on the market, with a 110 dB built-in siren and the option to link it to an outdoor lighting system.
The Somfy outdoor camera forms part of the complete Somfy Plug and Play security products range and is compatible with Smart Home systems, such as Works With Nest, IFTTT, Amazon Alexa and Google.
Features:
- Scare burglars off with smart motion detection and a siren
- Full HD camera with night vision
- Powerful siren (110 dB)
- Talk to intruders via the built-in speaker
- Motion detection: immediately starts recording when motion is detected
- Image storage in the cloud
- Connect via powersupply or external lighting
- Compatible with known Smart Home systems
- Somfy Outdoor Camera - network surveillance camera
- Network surveillance camera - fixed - outdoor - weatherproof
- Audio
- Yes: built-in speaker, built-in microphone
- Camera Mount Type
- Wall mount
- 14.725 cm x 8.5 cm x 15.08 cm
- 512 g
- Anthracite grey
- Connectivity Technology
- Wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 1920 x 1080
- Frame Rate (max)
- 30 frames per second
- Motion Detection
- Video Modes
- 1080p
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0
- Platform
- Nest, IFTTT, Somfy TaHoma
- Intelligent Assistant
- Google Assistant, Alexa
- Voltage
- AC 120/230 V
- Motion Detection Technology, reset button, High Dynamic Range (HDR), built-in siren
- 2-year warranty
- Environmental Parameters (operating)
- -20 °C - 50 °C
- Audio Support
- Camera Mount Type
- Wall mount
- Wireless
- 14.725 cm
- 8.5 cm
- 15.08 cm
- 512 g
Camera
- Colour - Day&Night - fixed - outdoor - weatherproof
- Max Digital Video Resolution
- 1920 x 1080
- Motion Detection
- Video Modes
- 1080p
- Digital Zoom
- 8
- Infrared LEDs
- Infrared Distance
- 8 m
- Frame Rate (max)
Lens Construction
- Horizontal Field of View (degree)
- 130
- Network Interface
- Included Accessories
- Wall mount kit, allen wrench, 2 screws, reset tool
- AES-256, IP54
- Anthracite grey
- Power Requirements
- AC 120/230 V
Internet of Things (IoT)
- Platform
- Limited warranty - 2 years
- -20 °C
- 50 °C
