Somfy One
Somfy One
Quicklinx: DMS6WS00 Mfr#: 2401492A
Type: Home security system
Compatible With: Alexa, Google Assistant, IFTTT, Nest + 1 more
£158.33 ex VAT
£189.99 inc VAT
Express delivery Order within the next 6 hours for delivery tomorrow
Somfy One - wireless alarm system with full HD camera, siren, motion detector and privacy protection.
With Somfy One, you’ll have everything you need in one go when it comes to your security. And that is quite handy. Somfy One is a fully stand-alone system. You simply install it in a strategically smart spot, activate it using the Somfy Protect app, and you’re good to go!
As soon as the camera detects movement, the alarm goes off and you get a push message on your smartphone. And you can view the images live and rewind by 10 seconds.
The siren that goes off will provide the deterrent you’re looking for. But you can always warn the police straight away too. And what if you’re not reachable? No problem. You can add several people to the app who will then receive a push message if there’s something suspicious going on, so that they can take steps immediately. By the way, you can also turn the siren off via the app.
And what if you’ve got pets? You can configure the Somfy One so that the camera will not react if your favourite pet happens to wander past the lens.
Do you value your privacy? Somfy One takes that into account. Because as soon as you enter the room, the camera shutter closes. So no one can watch what’s going on. Easy to expand the Somfy One with other Somfy Protect accessories, such as a window or door sensor, for instance.
Features:
  • Full HD video camera; pin-sharp images that ensure nothing escapes you
  • 90 DB siren: fully integrated and loud enough to scare off intruders
  • Motion detector: the camera starts recording as soon as it detects movement
  • Active privacy shutter: your private life is automatically shielded
  • Plug and play: the system is active and you’ll be done within 10 minutes!
  • Compatible: so you can expand it with various nifty Somfy Protect accessories
  • Powerful, intruder-deterrent siren
    If an intrusion is detected at your home, the siren goes off automatically to scare off the burglar. If you prefer, you can trigger the siren manually with a simple click from your smart phone.
  • A photo and video as proof
    As soon as your camera detects an intruder, their photo is immediately taken and the action is videotaped for a few seconds. All this is yours at no additional cost.
  • A community available to intervene
    Share access to your system with your neighbors, friends or family. At a slight alert, they will be able to intervene on site if you're not available.
  • Protecting your privacy
    To protect your privacy, your Somfy's motorized shutter closes automatically when you return home and opens when you leave. From your application, you can open and close it when you want to.
  • Easy to install
    Place your Somfy One in the desired location and plug it in. With just a few clicks from your app, your system is installed and working. Moving your Somfy One is easy because you don't need to re-install it.
  • Accurate detection
    Somfy One is equipped with advanced motion detection capabilities. Don't worry anymore about false alarms, branches moving against the window or your pet roaming around when you're not home.
Somfy ONE - network surveillance camera
Network surveillance camera - fixed
Audio
Yes: built-in speaker, built-in microphone
9 cm x 9 cm x 11 cm
260 g
Wireless
Camera
Colour - Day&Night
Frame Rate (max)
30 frames per second
Motion Detection
Video Modes
1080p
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, 868MHz radio
Platform
Nest, IFTTT, Somfy TaHoma
Intelligent Assistant
Google Assistant, Alexa
1 - micro-USB cable - external - 3 m
Voltage
DC 5 V
Motion Detection Technology, built-in siren
Environmental Parameters (operating)
0 °C - 45 °C
Audio Support
Wireless
9 cm
9 cm
11 cm
260 g
Camera
Colour - Day&Night - fixed
Motion Detection
Video Modes
1080p
Digital Zoom
8
Infrared LEDs
Infrared Distance
6 m
Frame Rate (max)
Network Interface
1 x micro-USB cable - external - 3 m
Power Requirements
DC 5 V
Internet of Things (IoT)
Platform
Intelligent Assistant Compatible
45 °C
Compatible With: IFTTT
Compatible With: Nest
Compatible With: Siri
Brand: Somfy
Price Range Ex VAT: 150 - 300
