Somfy One+ Alarm System
Quicklinx: DMSCWS00 Mfr#: 2401493A
£233.33 ex VAT
£279.99 inc VAT
Somfy One + wireless alarm system with an HD camera and siren.
With Somfy One +, you’ll have everything you need in one go when it comes to your security. And that is quite handy. Somfy One + is a fully stand-alone system. You simply install it in a strategically smart spot, activate it using the Somfy Protect app, and you’re good to go!
As soon as the camera detects movement, the alarm goes off and you get a push message on your smartphone. And you can view the images live and rewind by 10 seconds. The siren that goes off will provide the deterrent you’re looking for. But you can always warn the police straight away too.
And what if you’re not reachable? No problem. You can add several people to the app who will then receive a push message if there’s something suspicious going on, so that they can take steps immediately.
By the way, you can also turn the siren off via the app.
And what if you’ve got pets? You can configure the Somfy One + so that the camera will not react if your favourite pet happens to wander past the lens.
Do you value your privacy? Somfy One + takes that into account. Because as soon as you enter the room, the camera shutter closes. So no one can watch what’s going on.
And it’s really easy to expand the Somfy One + with other Somfy Protect accessories, such as a window or door sensor, for instance.
Keeps your home well protected, even during power outages.
The Somfy One + features a long lasting built-in battery that stays working for up to 6 hours. As a result, the Somfy One + protects your home even when the power fails.
If something happens during the power outage, the Somfy One + will trigger its built-in siren and begins to record immediately. The Somfy One + also comes with one door/window contact and one key fob.
  • Full HD video camera; pin-sharp images that ensure nothing escapes you
  • 90 DB siren: fully integrated and loud enough to scare off intruders
  • Motion detector: the camera starts recording as soon as it detects movement
  • Active privacy shutter: your private life is automatically shielded
  • Plug and play: the system is active and you’ll be done within 10 minutes!
  • Compatible: so you can expand it with various nifty Somfy Protect accessories
  • Backup battery up to 6 hours
Somfy ONE+ - network surveillance camera
Network surveillance camera - fixed
Audio
Yes: built-in speaker, built-in microphone
9 cm x 9 cm x 11 cm
260 g
Wireless
Camera
Colour - Day&Night
Frame Rate (max)
30 frames per second
Motion Detection
Video Modes
1080p
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, 868MHz radio
1 - micro-USB cable - external - 3 m
Voltage
DC 5 V
Motion Detection Technology, built-in siren
Environmental Parameters (operating)
0 °C - 45 °C
Audio Support
Wireless
9 cm
9 cm
11 cm
260 g
Camera
Colour - Day&Night - fixed
Motion Detection
Video Modes
1080p
Digital Zoom
8
Infrared LEDs
Infrared Distance
6 m
Frame Rate (max)
Network Interface
Remote control, door/window sensor
1 x micro-USB cable - external - 3 m
Power Requirements
DC 5 V
Internet of Things (IoT)
Platform
Nest, IFTTT, Somfy TaHoma
Intelligent Assistant Compatible
Google Assistant, Alexa
45 °C
Type: Home security and monitoring system
Compatible With: Alexa
Compatible With: IFTTT
Compatible With: Nest
Compatible With: Siri
Brand: Somfy
Price Range Ex VAT: 150 - 300
