Somfy Keyfob
Somfy Keyfob
Quicklinx: DMT0WS00 Mfr#: 2401489A
Key fob automatically disarms your alarm and recognizes authorized users. It replaces the keypad used with more traditional security systems, which helps to avoid accidentally setting off the alarm.
Give a keyfob to family members, your housekeeper, or trusted neighbors. It alerts you anytime someone enters or leaves your home. Its 4 buttons let you arm, disarm, or set the system to partial mode. It also has a 1-click panic button that sends a silent alert via email or SMS, or triggers the alarm. To prevent false alarm, automatic deactivation only works if you enter through a door which is equipped with an intellitag.
Power supply
  • 1x CR2032 battery
Radio
  • Connects with Somfy One or Somfy Home Alarm via Bluetooth.
Battery life
  • 12 month life (under normal use conditions)
  • You will be notified automatically when power supply is low
Compatibility:
  • Somfy One
  • Somfy Home Alarm
Somfy Key Fob - remote control
Remote control
Power Source
Wireless
3.4 cm x 3.4 cm x 1 cm
Remote control
Power Source
Wireless
Max Range Open Space
50 m
CR2032
Battery Included
Required Qty
1
Warranty
3.4 cm
3.4 cm
1 cm
12 g
45 °C
