Somfy Intellitag
Somfy Intellitag
Quicklinx: DMT3WS00 Mfr#: 2401487A
£33.33 ex VAT
£39.99 inc VAT
IntelliTAG anti-intrusion sensor
Only IntelliTAG™ uses multiple sensors and an advanced algorithm to analyze vibration patterns and detect the first sign of a break-in BEFORE a door or window is opened.
IntelliTAG can tell the difference between normal events like a knock at the door or a ball bouncing, and potential threats, like drilling or hammering: no more false alarms. Within nanoseconds of the break-in attempt, IntelliTAG triggers the siren and sends an alert to your smartphone.
Universal adaptability for sliding or swinging doors or windows, one-step adhesive installation, and tamper protection.
Fast and easy installation
Sets up in minutes: Simply place it on any window or door. Connect with Smartphone. And go!
Radio
Radio communication between IntelliTAG and Link ensures system maintenance. Tamper protection in case of radio interference.
Power supply
  • Batteries: 1 x AA battery with 12 month life (under normal use conditions)
  • You will be notified automatically when power supply is low
Compatibility: - Somfy One - Somfy Home Alarm
  • Fast and easy installation
    Simply place it on any window or door. Connect with smartphone. And go!
  • Radio
Somfy Protect IntelliTAG - door and window sensor
Door and window sensor
Environment
Indoor, outdoor
Power Source
Wireless - Radio Technology Somfy (RTS)
6 cm x 2.8 cm x 1.35 cm
Environment
Indoor, outdoor
Power Source
Wireless
Max Range Open Space
200 m
Indoor/outdoor usage, tamper protection
AAA type
Battery Included
Required Qty
1
Battery Lifetime
1 year
Warranty
IP54
6 cm
2.8 cm
1.35 cm
28 g
45 °C
Type: Door and window sensor
Compatible With: Alexa
Compatible With: IFTTT
Compatible With: Nest
Compatible With: Siri
Brand: Somfy
Price Range Ex VAT: 0 - 50
