Somfy Indoor Motion Sensor
Quicklinx: DMSZWS00 Mfr#: 2401490A
Type: Motion sensor
Compatible With: Google Assistant, IFTTT, Nest, Alexa + 1 more
30 in stock
£49.99 ex VAT
£59.98 inc VAT
With its 130° wide angle and 7 m range, it will automatically trigger a 110 dB alarm if it detects an intrusion. You and your community will immediately be notified on your smartphone. Say goodbye to false alerts! Compatible with pets weighing less than 25 kg.
The motion sensor comes with a temperature sensor, which can be monitored at a glance directly from your Somfy Protect app.
Fast and easy instalation
  • Installs in minutes: It can be positioned on furniture or attached to the wall thanks to provided wall mount and double-sided adhesive.
  • The app guides the user step-by-step in positioning the sensor in the room. After installation, a test enables you to verify the sensor’s effectiveness.
  • The app is free for iOS 8 and higher and Android 4.1 and higher.
Main features:
  • 7 m detection range
  • Autoprotection
  • Indoor use
  • Pet-friendly
  • Temperature sensor
Power supply
  • Powered by one 1 CR123A battery.
  • 2-year autonomy in normal use (10 detections per hour).
  • You are automatically notified when the battery level is low.
Radio
The system’s protection is ensured by radio communication between the motion sensor and the Link plug.
Compatibility:
  • Somfy One
  • Somfy Home Alarm
Somfy Protect - motion sensor
Motion sensor
Environment
Indoor
Power Source
Wireless - Radio Technology Somfy (RTS)
Supported Host Device OS
iOS, Android
4.7 cm x 4.7 cm x 4.7 cm
Motion sensor
Environment
Indoor
Power Source
Wireless
Max Range Open Space
200 m
iOS 8.0 or later, Android 4.1 (Jelly Bean) or later
Pet immunity up to 25 kg
Motion Sensor
Detection Range
7 m
CR123A
Battery Included
Battery Lifetime
1 year
Warranty
4.7 cm
4.7 cm
4.7 cm
55 g
45 °C
Type: Motion sensor
Compatible With: IFTTT
Compatible With: Nest
Compatible With: Alexa
Compatible With: Siri
Brand: Somfy
Stock Status: In stock
