Somfy Home Alarm
Somfy Home Alarm
Quicklinx: DMT5WS00 Mfr#: 2401497A
£274.17 ex VAT
£329.00 inc VAT
With this comprehensive wireless home alarm pack, you can protect every nook and cranny in your house, the motion detector and the three door and window sensors that come as standard immediately send a push message to your smartphone if there is a burglary. A loud siren goes off at the same time.
The IntelliTAG™ is the only door and window sensor that warns you if there is an attempted break-in BEFORE the intruders break in. In the process, it can recognise the difference between a ball bumping the door and the door being forced open.
And what about your pets? With the smart motion detector, animals up to 25 kg can romp around and run past the camera without setting off the alarm.
For convenience, you get two key fobs that you can use to switch the alarm on and off. Even better, as soon as you get close to your house, the system ‘sees’ that you’re standing in front of the door and is automatically switched off. Which is really useful if you happen to have your hands full.
The Somfy Home Alarm can be expanded to include various handy accessories, such as cameras and sensors, for instance.
  • All-round home alarm system: every nook and cranny is protected, and it comes complete with a siren
  • IntelliTAG™: smart door/window sensor that warns you BEFORE the intruder has broken in
  • Motion detector: reacts immediately to unexpected temperature differences while ignoring pets
  • Push messages: tell you about suspicious activities immediately via your smartphone
  • Easy to install: sensors can be placed on or stuck to a surface
  • Plug and play: installed and active within 10 minutes
  • Somfy app: helps to remind you that you have to activate the alarm
What's included?
  • 1x Link
  • 1x Indoor siren
  • 1x Motion detector
  • 3x Intellitag
  • 2x keyfob
Each component has its own role to play:
Link
The heart of your Somfy security system, it connects to your Internet through Wi-Fi and links all the elements wirelessly.
IntelliTAG
Smart wireless door and windows sensor, it sets a security perimeter around your house and detects intrusion attempts.
Key Fob
Personal remote control that automatically disarms your system when you get back home.
Indoor Siren
Wireless, it sounds at 110db when an attempted break-in is detected. Set it up anywhere, it adapts to your interior design.
Indoor Motion Sensor
Small, discreet and wireless, it detects all human movements while remaining indifferent to pets.
You can enhance your Somfy Protect system even more:
Outdoor Siren
Wireless, it can be placed either outside of your home. When an attempted break-in is detected, it sounds at 112dB.
Security Camera
The only smart home security camera with a motorized shutter that protects your home AND privacy.
Radio range extender
Increases your Link's radio range; extends radio coverage between all Somfy Protect system devices and guarantees reliable, high-level security.
Somfy Protect Home Alarm - home security system
Home security system
Power Source
Package Content
Motion sensor, siren, 2 x remote controls, Wi-Fi hub, 3 x door and window sensors
Wireless - 802.11b/g/n, Radio Technology Somfy (RTS)
Supported Host Device OS
iOS, Android
Power Source
Package Content
Wireless
iOS, Android
Motion Sensor
130° detection angle
Warranty
Dimensions & Weight Details
System hub: 8.9 cm x 8.9 cm x 3 cm x 132 g , Remote control: 3.4 cm x 3.4 cm x 1 cm x 12 g , Motion sensor: 4.7 cm x 4.7 cm x 4.7 cm x 55 g , Siren: 17.5 cm x 17.5 cm x 4.5 cm x 985 g , Door and window sensor: 6 cm x 2.8 cm x 1.35 cm x 28 g
Type: Home security system
Compatible With: Alexa
Compatible With: IFTTT
Compatible With: Nest
Compatible With: Siri
Brand: Somfy
Price Range Ex VAT: 150 - 300
