Somfy Home Alarm+ Outdoor Camera Grey
Quicklinx: FM41WS00 Mfr#: 1870552
Type: Home security system
Compatible With: Alexa, Google Assistant
10 in stock
£490.84 ex VAT
£589.00 inc VAT
With this comprehensive Somfy Home Alarm Pack, you can protect every nook and cranny in and outside your house. The motion detector and the three door and window sensors that come as standard immediately send a push message to your smartphone if there is a burglary. A loud siren goes off at the same time.
The thought of someone breaking into your home, prowling around your house, looking for valuables, perish the thought! What you really want is for the thieves or burglars to just keep off your property.
The IntelliTAG is the only door and window sensor that warns you if there is an attempted break-in BEFORE the intruders break in. In the process, it can recognize the difference between a ball bumping the door and the door being forced open.
The camera also comes with a smart activation function. When you get back home, the system will recognize you and switch itself off, and if you go out again, you'll get a reminder via the app on your smartphone to re-activate the camera. That's convenience for you!
The Somfy Outdoor Camera and all Protect security products are compatible with Smart Home systems, such as IFTTT, Amazon Alexa and Google.
Somfy Home Alarm + Outdoor Camera - home security system
Environment
Indoor, outdoor
Integrated Sensors
Temperature
Internet of Things (IoT) Platform
Somfy TaHoma
Intelligent Assistant
Google Assistant, Alexa
Package Content
Motion sensor, central controller, camera, siren, 2 x remote controls, 3 x door and window sensors
Wireless - 802.11b/g/n
Siren Sound Level
110 dB
Frequency Band
2.4 Ghz
Camera
Max Resolution 1920 x 1080 - audio - Day&Night
Camera Zoom
8x digital zoom
Grey, white
Environment
Indoor, outdoor
Integrated Sensors
Temperature
Package Content
Wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 Ghz
Siren Sound Level
110 dB
Push notification, pet immunity up to 25 kg, tamper protection, face detection, radio jamming detection, IntelliTAG technology
Platform
Somfy TaHoma
Compatible Services
IFTTT
Camera
Day & Night Functionality
Digital Zoom
8
Audio Support
Max Digital Video Resolution
1920 x 1080
Video Modes
1080p
Built-in speaker, built-in microphone, Face Recognition, infrared cut filter, High Dynamic Range (HDR), motion detection, 130° field of view
Motion Sensor
Detection Range
7 m
Grey, white
Encryption Algorithm
WPA2, 256-bit AES, WEP
IP54
Dimensions & Weight Details
Camera: 15 cm x 15 cm x 8.5 cm x 512 g , Door and window sensor: 6 cm x 2.8 cm x 1.35 cm x 28 g , Motion sensor: 4.7 cm x 4.7 cm x 55 g , Remote control: 3.4 cm x 3.4 cm x 1 cm x 12 g , Siren: 17.5 cm x 17.5 cm x 4.5 cm x 985 g , Central controller: 8.9 cm x 3 cm x 8.9 cm x 132 g
Brand: Somfy
Stock Status: In stock
