Somfy Connected Thermostat Wireless
Quicklinx: FM3XWS00 Mfr#: 1870567
Type: Thermostat
Compatible With: Alexa
£107.50 ex VAT
£129.00 inc VAT
The connected thermostat that personalizes your comfort according to your house and your habits.
Enjoy comfort with ease
Because not everyone has the same concept of comfort, Somfy has developed the Connected Thermostat which personalises your comfort according to your house and your habits. And all that whilst helping you to reduce your energy bill. Adjust the temperature on the thermostat or using the iOS or Android smartphone app.
  • Humidity sensor
  • Geolocation function
  • Self-learning based on your home environment
  • Open window detection
  • Access management: child / adult account
MORE COMFORT WITH MORE SENSORS The connected thermostat takes into account both the temperature and humidity levels in your home, to be closer to the temperature you actually feel and offers you maximum comfort.
KEEP AN EYE ON YOUR ENERGY CONSUMPTION AND RECEIVE PERSONALIZED ENERGY COACHING. The Somfy connected thermostat analyses the energy performance of your home, the weather conditions and your usage habits. You can view in real time, on the smartphone application, the estimated amount of your energy bill. Personalized advice will be offered to improve your consumption and reduce its impact on your bill.
ENJOY MORE FREEDOM THANKS TO GEOLOCATION AND REMOTE CONTROL. The Somfy connected thermostat automatically adapts to you schedule. By activating the geolocation function, when you move away from home, the temperature decreases, and as you get closer, it increases.
ENJOY THE SOMFY ECOSYSTEM With TaHoma, combine your thermostat with your Somfy blinds for even greater efficiency. You can create a "smart" programming combining thermostat, sun sensor and blinds to save even more energy.
Contents - 1x thermostat - 1x internet gateway - 2x AA batteries - 1x wireless receiver - 2x 1m cable - 1x manual - 1x quickstart guide
  • More comfort with more sensors
  • Keep an eye on your energy consumption and receive personalized energy coaching
  • Enjoy more freedom thanks to geolocation and remote control
  • Enjoy the Somfy ecosystem
Somfy Connected Smart Thermostat - Wireless - thermostat
Thermostat
Functions
Temperature measuring, humidity measurement
Power Source
Internet of Things (IoT) Platform
Google Home, Somfy TaHoma
Intelligent Assistant
Alexa
Wireless - Wi-Fi
Grey, white
5-year warranty
10.2 cm x 3.5 cm x 9 cm
Thermostat
Functions
Power Source
Wireless - Wi-Fi
Android, Apple iOS
Platform
Compatible Services
IFTTT
Alexa
Temperature Range
5 - 26 °C
AA type
Battery Included
Required Qty
2
Receiver, gateway
Grey, white
Warranty
5-year warranty
ISO 140001, OHSAS 18001, EN 62479:2010, ISO 90001
10.2 cm
3.5 cm
9 cm
108 g
Dimensions & Weight Details
Gateway: 6 cm x 6.2 cm x 7.15 cm x 75 g , Thermostat: 10.2 cm x 3.5 cm x 9 cm x 108 g , Receiver: 10.2 cm x 3.4 cm x 9 cm x 182 g
Type: Thermostat
Brand: Somfy
