Smart Technologies SP518 Podium with Notebook
Quicklinx: BR60WS00 Mfr#: SP518-NB
Create engaging presentations and dynamic collaboration sessions with the SMART Podium 500 series interactive pen display. You can display, interact with and write over digital content on SMART Podium, all while displaying that content on a larger screen in the same room or from a remote location.
The versatile interactive pen display works as a powerful presentation tool and supports collaboration in virtually any learning space, from small classrooms or labs to large auditoriums. Open presentations, documents, applications, websites and multimedia files, write notes over them in digital ink and save your work for distribution or later reference. In rooms equipped with SMART Board interactive whiteboards or displays, you can work with content from anywhere in the room and display it on the interactive whiteboard or display. And in distance education scenarios, teachers and students can share screens using SMART Bridgit conferencing software and mark up documents and files as if they were in the same room.
With the SMART Podium interactive pen display, you can create and deliver engaging, interactive, digital presentations. Because your course material is in front of you and displayed on a large screen, you can focus on keeping students engaged. The display's tethered pen acts as a mouse to navigate content on your screen - control computer applications and write notes in multiple digital ink colors over applications, slides, websites and videos. The Smooth Tilt Stand helps support a natural writing posture. The intuitive function buttons - illuminated for dimly lit rooms - enable you to change ink colors, erase, highlight and emphasize content, access the mouse function, and save and share your work.
  • DViT (Digital Vision Touch) technology
    SMART Podium features SMART's own DViT technology. With cameras incorporated in the bezel to detect pen touch and movement, DViT provides a responsive, accurate writing experience.
  • Widescreen HD interactive display
    View your content in sharp detail with an 18.5" (47 cm) HD progressive-scan LCD display. The 18.5" display features 720p resolution.
  • Elegant design
    SMART Podium features a slim profile, a minimized bezel with a magnetic pen rest and a reduced overall footprint, complementing virtually any learning space.
  • Console buttons
    Access the right-click button, select pen colors or the eraser, or launch the On-Screen Keyboard, Screen Capture tool or SMART Notebook collaborative learning software. The buttons are illuminated for use in dimly lit rooms. They are also preconfigured but can be programmed to suit the shortcuts you use most.
  • Tethered pen
    Control your computer from SMART Podium and comfortably write over any application with the battery-free tethered pen. Because the pen is the point of contact on the interactive screen, you can rest your hand on the screen while writing notes.
  • SMART Ink
    SMART Ink smooths out your handwriting to improve legibility. You can write notes over any application and save them into several common applications, including Microsoft Office 2010 programs or Adobe Acrobat Pro. You can also turn handwritten notes into text objects that you can manipulate.
  • Smooth Tilt Stand
    Smoothly and easily adjust the position of your SMART Podium, so you can comfortably rest your hand on the display while you make notes and maintain eye contact with your students.
  • HDCP compliant
    Ensures that HDCP-encrypted content can be displayed.
  • High-speed USB 2.0 ports
    Access three high-speed USB 2.0 ports to connect peripherals such as a USB drive, document camera or personal mobile device. A fourth USB 2.0 on the rear connection panel is provided to connect a computer.
  • Kensington security lock slot
    Secure SMART Podium by connecting a compatible lock and cable.
  • Future proof
    Flexible video connection options (DVI or VGA), wide-format aspect ratio and scaling options ensure SMART Podium is compatible with existing and future technology investments.
SMART Podium interactive pen display SP518-NB - LCD monitor - 18.5"
LCD monitor - 18.5"
Digital pen, USB 2.0 hub
Aspect Ratio
16:9
Native Resolution
HD 720p 1366 x 768
Brightness
180 cd/m²
Contrast Ratio
580:1
Response Time
5 ms
Colour Support
16.8 million colours
Input Connectors
DVI-I
Display Position Adjustments
Tilt
Voltage
46.7 cm x 7.6 cm x 33 cm
UL, TUV GS, C-Tick, NOM, SASO, CB, CCC, PSB, FCC, IRAM, RoHS, WEEE, GOST-R
Display Type
LCD monitor / TFT active matrix
Diagonal Size
18.5"
Built-in Devices
USB 2.0 hub
Aspect Ratio
16:9
Native Resolution
HD 720p 1366 x 768
Brightness
180 cd/m²
Contrast Ratio
580:1
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 Hz
Horizontal Refresh Rate
76 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
HDCP
46.7 cm x 7.6 cm x 33 cm - without stand
Input
Digital pen
Movement Detection Technology
Digital vision touch
DVI-I , DVI-I , USB 2.0 upstream (Type B) , 3 x USB 2.0 downstream
Mechanical
Tilt
Tilt Angle
46.5
VESA Mounting Interface
100 x 100 mm
Digital pen
1 x DVI cable , 1 x DVI-VGA cable , 1 x USB cable
Backlight Life
30,000 hours
Power Supply
External
Input Voltage
Included Software
SMART Notebook
Apple MacOS, Microsoft Windows
Dimensions & Weight Details
With stand - width: 46.7 cm - depth: 29.8 cm - height: 32.1 cm - weight: 8.9 kg , Without stand - width: 46.7 cm - depth: 7.6 cm - height: 33 cm
5 °C
35 °C
20 - 80% (non-condensing)
