Create engaging presentations and dynamic collaboration sessions with the SMART Podium 500 series interactive pen display. You can display, interact with and write over digital content on SMART Podium, all while displaying that content on a larger screen in the same room or from a remote location.
The versatile interactive pen display works as a powerful presentation tool and supports collaboration in virtually any learning space, from small classrooms or labs to large auditoriums. Open presentations, documents, applications, websites and multimedia files, write notes over them in digital ink and save your work for distribution or later reference. In rooms equipped with SMART Board interactive whiteboards or displays, you can work with content from anywhere in the room and display it on the interactive whiteboard or display. And in distance education scenarios, teachers and students can share screens using SMART Bridgit conferencing software and mark up documents and files as if they were in the same room.
With the SMART Podium interactive pen display, you can create and deliver engaging, interactive, digital presentations. Because your course material is in front of you and displayed on a large screen, you can focus on keeping students engaged. The display's tethered pen acts as a mouse to navigate content on your screen - control computer applications and write notes in multiple digital ink colors over applications, slides, websites and videos. The Smooth Tilt Stand helps support a natural writing posture. The intuitive function buttons - illuminated for dimly lit rooms - enable you to change ink colors, erase, highlight and emphasize content, access the mouse function, and save and share your work.
DViT (Digital Vision Touch) technology
SMART Podium features SMART's own DViT technology. With cameras incorporated in the bezel to detect pen touch and movement, DViT provides a responsive, accurate writing experience. -
Widescreen HD interactive display
View your content in sharp detail with an 18.5" (47 cm) HD progressive-scan LCD display. The 18.5" display features 720p resolution. -
Elegant design
SMART Podium features a slim profile, a minimized bezel with a magnetic pen rest and a reduced overall footprint, complementing virtually any learning space. -
Console buttons
Access the right-click button, select pen colors or the eraser, or launch the On-Screen Keyboard, Screen Capture tool or SMART Notebook collaborative learning software. The buttons are illuminated for use in dimly lit rooms. They are also preconfigured but can be programmed to suit the shortcuts you use most. -
Tethered pen
Control your computer from SMART Podium and comfortably write over any application with the battery-free tethered pen. Because the pen is the point of contact on the interactive screen, you can rest your hand on the screen while writing notes. -
SMART Ink
SMART Ink smooths out your handwriting to improve legibility. You can write notes over any application and save them into several common applications, including Microsoft Office 2010 programs or Adobe Acrobat Pro. You can also turn handwritten notes into text objects that you can manipulate. -
Smooth Tilt Stand
Smoothly and easily adjust the position of your SMART Podium, so you can comfortably rest your hand on the display while you make notes and maintain eye contact with your students. -
HDCP compliant
Ensures that HDCP-encrypted content can be displayed. -
High-speed USB 2.0 ports
Access three high-speed USB 2.0 ports to connect peripherals such as a USB drive, document camera or personal mobile device. A fourth USB 2.0 on the rear connection panel is provided to connect a computer. -
Kensington security lock slot
Secure SMART Podium by connecting a compatible lock and cable. -
Future proof
Flexible video connection options (DVI or VGA), wide-format aspect ratio and scaling options ensure SMART Podium is compatible with existing and future technology investments.
- SMART Podium interactive pen display SP518-NB - LCD monitor - 18.5"
- Digital pen, USB 2.0 hub
- Aspect Ratio
- 16:9
- Native Resolution
- HD 720p 1366 x 768
- Brightness
- 180 cd/m²
- Contrast Ratio
- 580:1
- Response Time
- 5 ms
- Colour Support
- 16.8 million colours
- Input Connectors
- DVI-I
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Dimensions (WxDxH) - without stand
- 46.7 cm x 7.6 cm x 33 cm
- UL, TUV GS, C-Tick, NOM, SASO, CB, CCC, PSB, FCC, IRAM, RoHS, WEEE, GOST-R
- 2-year warranty
- Display Type
- LCD monitor / TFT active matrix
- Diagonal Size
- 18.5"
- Built-in Devices
- USB 2.0 hub
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 180 cd/m²
- Contrast Ratio
- 580:1
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 56 Hz
- Horizontal Refresh Rate
- 76 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- HDCP
- 46.7 cm x 7.6 cm x 33 cm - without stand
Input
- Digital pen
- Movement Detection Technology
- Digital vision touch
- DVI-I , DVI-I , USB 2.0 upstream (Type B) , 3 x USB 2.0 downstream
Mechanical
- Tilt
- Tilt Angle
- 46.5
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Digital pen
- Cables Included
- 1 x DVI cable , 1 x DVI-VGA cable , 1 x USB cable
- Backlight Life
- 30,000 hours
- Power Supply
- External
- Input Voltage
- Included Software
- SMART Notebook
- OS Required
- Apple MacOS, Microsoft Windows
- Dimensions & Weight Details
- With stand - width: 46.7 cm - depth: 29.8 cm - height: 32.1 cm - weight: 8.9 kg , Without stand - width: 46.7 cm - depth: 7.6 cm - height: 33 cm
- Limited warranty - 2 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
