Your SMART Board 480iv2 interactive whiteboard system combines a SMART Board 480 interactive whiteboard, a SMARTV30 projector, and other accessories. The SMARTV30 projector provides a bright high-resolution image on a short boom delivering high-definition, high-performance interactivity that is virtually shadow-free and glare-free. You can do everything you can do at your computer - open and close applications, meet with others, create new documents or edit existing ones, visit websites, play and manipulate video clips and more - just by touching the interactive surface.
The SB480iv2 system supports video and audio connections from a variety of devices including DVD and Blu-ray players, document cameras, and other high-definition sources, and can project media from these sources onto the interactive screen. All HDMI inputs are HDCP compliant.
- SMART Board Interactive Whiteboard System SB480iv2 - interactive whiteboard - USB - dark grey
- Interactive whiteboard
- Connectivity Technology
- Wired - USB
- Display
- Projector - 1024 x 768
- Dark grey
- 23.2 kg
- Movement Detection Technology
- Digital vision touch
- USB bus powered
- Cable Length
- 3 m
- OS Required
- Linux, Microsoft Windows
- 23.2 kg
- Dark grey
Input Device
- Wired
- Interface
- USB
- Active Area
- 160.5 cm x 158.6 cm
- Cable Length
- 3 m
- USB bus powered
Display
- Projector
- Native Resolution
- 1024 x 768
- Image Brightness
- 3000 lumens
- Image Contrast Ratio
- 3000:1
- Vertical Refresh Rate
- 25 - 75 Hz
- Horizontal Refresh Rate
- 15 - 72 kHz
- 1 x USB - 4 pin USB Type A
- Included Accessories
- SMART Pen Tray, interactive pen
- CSA, UL, TUV GS, C-Tick, BSMI, NOM, SABS, CB, CCC, FCC, S Mark, KC, BIS
- Software Included
- SMART Notebook
- OS Required
- 5 °C
- 35 °C
- 0 - 80% (non-condensing)
