Product
Brand
Smart Technologies Kapp
Connect to Kapp with Your Smartphone and Share Content With Others!
Quicklinx: 9W68WS00 Mfr#: 1024494
The SMART kapp™ 42" capture board enables you to collaborate with others in a simple but powerful way. Write and draw on the capture board like you would a regular dry erase board. You can then connect a Bluetooth®-enabled mobile device to the capture board by scanning a Quick Response (QR) code or by tapping the Near Field Communication (NFC) tag. When you first connect your mobile device, you're directed to the Apple App Store or Google Play™ to download the SMART kapp app. After you download and install the app, you can use it to connect to your capture board and share content with others.
Simple, secure and stylish
Get started right away
Put it up. Plug it in. Create.
Easily save and share notes
Store content as snapshots on a mobile device. Automatically share snapshots to your Evernote™ account.
Real-time sharing
Remote participants can be invited to view content in real-time using any browser
Refined inking
Write and erase on the sleek, glass surface without ever staining it.
Full data security
Shared content is immediately deleted when you disconnect your device.
Weight 35 lb. (16 kg)
Shipping dimensions 47 1/4" × 25" × 5 3/8" (119.9 cm × 63.5 cm × 13.6 cm)
Shipping weight 47 lb. (21.3 kg)
SPECIFICATIONS
SMART KAPP 42" CAPTURE BOARD (KAPP42)
Parts and features
Included parts
SMART kapp 42" capture board
Dry-erase marker (×3)
Eraser
Bracket and hardware for mounting the capture board to a wall
Digital capture technology
DViT® (Digital Vision Touch) technology
Wireless technology
Bluetooth 2.1 + EDR2
Capture options Establish a Bluetooth wireless connection with a supported mobile device (see below) by doing one of the following:
* Scan the capture board's unique QR code
* Tap the capture board's NFC tag (Android™ devices only)
Connect a USB drive
USB drive support
USB 2.0 Type-A receptacle
Support for FAT-formatted USB drives only
Mobile device support
Apple devices
iOS 7.1 or later operating system software
50 MB storage
iPhone 4S or later
Third generation iPad or later
First generation iPad mini or later
Fifth generation iPod touch or later
Android devices
Android 4.1 (Jelly Bean) or later operating system
50 MB of storage (internal or SD card)
Devices meeting the following specifications:
* 1024 MB of RAM
* 720p or better screen resolution
* Bluetooth 2.1 + EDR
* NFC (recommended)
* 3 megapixel or better rear-facing camera (recommended)
Mounting
Options
Included mounting bracket
Standard VESA® 400 mm × 400 mm mounting bracket
Recommended height
69" (175.3 cm) from the floor to the middle of the included mounting bracket
Bolt requirements for VESA mounting bracket
Size M6
To avoid damage to the capture board, ensure the bolt is no longer than 1/2" (1.2 cm) plus the width of the washer and the width of the bracket
Power specifications
5V, 3A
Power cable
9' 10" (3 m) power cable
Storage and operating requirements
Storage
Temperature -40-140°F (-40-60°C)
Humidity 5-95% relative humidity, non-condensing
Operating
Temperature: 41-95°F (5-35°C)
Humidity: 10-80% relative humidity, non-condensing
Certification and compliance
Regulatory certification
CE, ETL, C-Tick, FCC
Environmental compliance
European Union: REACH, RoHS, WEEE and Packaging
US: Packaging and Conflict Minerals
