The most accurate, natural, and responsive touch experience from corner to corner. Fingers glide effortlessly over the surface, providing hours of error-free use in perfect comfort. Students can see their contributions free from interruption by their partner. Using different colored ink, you can write independently and simultaneously in any lesson activity to open new collaborative opportunities.
Silktouch technology
The most accurate, natural, and responsive touch experience from corner to corner. Fingers glide effortlessly over the surface, providing hours of error-free use in perfect comfort. -
Pen ID
Students can see their contributions free from interruption by their partner. Using different colored ink, you can write independently and simultaneously in any lesson activity to open new collaborative opportunities. -
Object awareness
You already know how to use it. Offering the most intuitive experience by automatically differentiating between a finger, pen or palm, do what comes naturally. Touch, write, erase. Simplicity at its finest. -
SMART ink technology
Writing is natural and looks better with SMART ink. Whether you're using a pen or finger, each stroke is a work of art. Its realistic digital ink improves legibility, so teachers don't have to re-write and students feel confident contributing. -
4K Ultra HD resolution
Durable commercial-grade, glare-free LED panels display brilliantly detailed 4K Ultra HD images and text (3840 x 2160 pixels). Crisp content clarity and readability keeps students involved no matter where they're seated in the room. No more downtime fixing burnt out projector bulbs, no shadows getting in the way, no glare or hot spots, and no faded images. -
Simultaneous touch points
With 4 simultaneous touch points, two students can use gestures, like zoom, rotate and flip, at the same time. The natural learning experience develops essential life-long collaboration skills without students realizing it.
- SMART Board 6075 75" LED-backlit LCD display - 4K
- Product Type
- LED-backlit LCD flat panel display with touchscreen
- Diagonal Class
- 75"
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- DisplayPort
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Included Accessories
- 2 touch pens, SMART Notebook software
- Voltage
- AC 120/230 V (50/60 Hz)
- 350 Watt
- Power Consumption Stand by
- 1.7 Watt
- 173.1 cm x 12 cm x 110.2 cm
- 84 kg
- 2-year warranty
- Product Type
- 350 Watt
- Diagonal Class
- 75"
- Combined With
- Touchscreen
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- DisplayPort
- 173.1 cm
- 12 cm
- 110.2 cm
- 84 kg
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- LED backlight
- Image Contrast Ratio
- 1200:1
- Brightness
- 360 cd/m²
- Viewing Angle
- 178 degrees
- Touchpoints Qty
- 4
- Response Time
- 12 ms
- Optical Touch technology
Stands & Mounts
- Flat Panel Mount Interface
- 600 x 400 mm
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
- Connector Type
- 2 x HDMI input - side , 3 x USB 2.0 - side , Audio line-out - side , DisplayPort - side , Serial , USB 2.0 - bottom
- Cables Included
- USB cable - 5 m
- UL, VCCI, EMC, IC, FCC, RoHS, WEEE, PSE Mark, REACH, KC
- Power Device
- Power supply
- Input Voltage
- 1.7 Watt
- Limited warranty - 2 years
- Width (Shipping)
- 191.6 cm
- Depth (Shipping)
- 35.5 cm
- Height (Shipping)
- 138 cm
- Weight (Shipping)
- 108 kg
- 5 °C
- 35 °C
- 5 - 80% (non-condensing)
