Smart Technologies 65" SMART Board® 6065 4K UHD HDMI DP USB + 5 Year Warranty
Quicklinx: CJXPWS00 Mfr#: SPNL-6065-V2
Select:
  • 65"
The SMART Board 6065-V2 interactive flat panel combines SMART’s proprietary DViT (Digital Vision Touch) technology with a premium touch experience and the power on a 65" LED display. For simple and powerful digital whiteboarding, this interactive flat panel is also SMART kapp iQ enabled. The 4K Ultra HD display provides optimal image clarity and wide viewing angles. With the Pen ID feature, you can assign different appearances to the pens and write or draw over any application in digital ink. Object Awareness allows you to perform mouse functions with your finger, write in digital ink with the pen, and erase with your palm or eraser — all without switching tools or modes. You can use a variety of gestures in applications, and two users can write or draw at the same time.
SMART Board 6065-V2 65" LED-backlit LCD display - 4K - for interactive communication
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
65"
Commercial Use
Yes - interactive
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
DisplayPort
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB
2 touch pens, SMART Notebook software
Voltage
189 Watt
Power Consumption Stand by
2.2 Watt
150.8 cm x 12 cm x 97.8 cm
60.9 kg
189 Watt
Diagonal Class
65"
Commercial Use
Yes - interactive
Combined With
Touchscreen
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
DisplayPort
150.8 cm
12 cm
97.8 cm
60.9 kg
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
1200:1
Brightness
338 cd/m²
Viewing Angle
178 degrees
Touchpoints Qty
8
Response Time
8 ms
Digital Vision Touch technology
Stands & Mounts
Flat Panel Mount Interface
300 x 400 mm
Media Player
USB Port
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Connector Type
2 x HDMI input , 3 x USB 2.0 , Audio line-out , DisplayPort , Serial , USB 2.0 - bottom
USB cable - 5 m
UL, CCC, IC, FCC, RoHS, WEEE, PSE Mark, REACH, KC, EAC, RCM, SPRING
Power supply
Input Voltage
2.2 Watt
Width (Shipping)
175.8 cm
Depth (Shipping)
30.3 cm
Height (Shipping)
126.1 cm
Weight (Shipping)
82.1 kg
5 °C
35 °C
5 - 80% (non-condensing)
