Your basket is empty
Smart Technologies E70 Interactive Flat Panel
Quicklinx: 9F0PWS00 Mfr#: SPNL-4070
Designed specifically for classrooms, the SMART Board E70 interactive flat panel combines a premium touch experience with the power of SMART Notebook collaborative learning software on a 70" display. The high-definition, shadow-free 70" (177.8 cm) LED display features low-friction coated glass that enables fingers to glide smoothly over the surface, facilitating a natural touch experience. The SMART Board E70 also virtually eliminates glare and provides an optimal view from any angle in the classroom, delivering an unparalleled viewing and writing experience to offer the best value for classrooms. The multitouch SMART Board E70 features freestyle multi-user interaction anywhere on the display with Windows 7 or 8, enabling students to collaborate without limitations.
SMART Board E70 interactive flat panel SPNL-4070 - LED monitor - Full HD (1080p) - 70"
LED-backlit LCD monitor - 70" - touchscreen
Touch-screen
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.807 mm
Contrast Ratio
4000:1
Input Connectors
3xHDMI, VGA
163.2 cm x 8.7 cm x 96.7 cm
77 kg
UL, cUL, IC, FCC, RoHS, WEEE, REACH
2 years warranty
Display Type
Diagonal Size
70"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.807 mm
Contrast Ratio
4000:1
Vertical Refresh Rate
85 Hz
Horizontal Refresh Rate
91 kHz
Backlight Technology
LED backlight
77 kg
Audio
Speakers - stereo
Output Power / Channel
10 Watt
Input
Touch-screen - touchscreen
Movement Detection Technology
Infrared
3 x HDMI , VGA , Component video (RCA x 3) , Composite video (RCA) , SPDIF output , USB , Serial , Audio line-in , 2 x audio line-in (RCA x 2)
Remote control, 2 x digital pens
1 x USB cable - 5 m , 1 x VGA cable - 1.8 m
AC 120/230 V (50 - 60 Hz)
Included Software
SMART Notebook
Apple MacOS, Microsoft Windows
10 °C
10 - 80% (non-condensing)
