The SMARTBoard 7075 interactive display with iQ is the hub of your classroom. iQ technology connects devices, lesson content and pedagogically relevant software to create a cohesive educational experience. PC-free embedded computing provides one-touch access to a diverse suite of SMART applications - Notebook lessons, amp workspaces, lab gamification activities and whiteboard - and collaborative tools, such as wireless screen sharing and a web browser. There's no need for wires, cables or manual software and firmware updates.
The 75" 4K ultra-high-definition LED display provides optimal image clarity and wide viewing angles. With the PenID feature, you can assign different appearances to the four pens and write or draw over any application in digital ink.
Object Awareness allows you to perform mouse functions with your finger, write in digital ink with the pen, and erase with your palm or eraser - all without switching tools or modes. You can use a variety of gestures in applications, and four users can write or draw at the same time.
- SMART Board 7075 Pro interactive display with iQ 7075 Pro - 75" LED-backlit LCD display - 4K - for interactive communication
- Product Type
- LED-backlit LCD flat panel display with touchscreen
- Diagonal Class
- 75"
- Commercial Use
- Yes - interactive
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- LAN, Bluetooth
- PC Interface
- VGA (HD-15), DisplayPort
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Picture Enhancements
- 72% Colour Gamut
- Speaker System
- 2 speakers
- USB
- Included Accessories
- Power cable, eraser, 4 pen styluses, SMART Meeting Pro software (room licence), iQ appliance, SMART Meeting Pro software (10 personal licences)
- Voltage
- AC 120/230 V (50/60 Hz)
- 147 Watt
- Power Consumption Stand by
- 2 Watt
- 175.4 cm x 12.4 cm x 109.5 cm
- 79 kg
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Product Type
- 147 Watt
- Diagonal Class
- 75"
- Commercial Use
- Yes - interactive
- Combined With
- Touchscreen
- Series
- 7075 Pro
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- 72% Colour Gamut
- 175.4 cm
- 12.4 cm
- 109.5 cm
- 79 kg
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- LED backlight
- Image Contrast Ratio
- 5000:1
- Brightness
- 360 cd/m²
- Viewing Angle
- 178 degrees
- Touchpoints Qty
- 10
- Response Time
- 8 ms
- Display Menu Language
- Chinese (traditional), Chinese (simplified), German, French, Italian, Norwegian, Swedish, Spanish, Japanese, Korean
- Pen ID, Object Awareness, presence detection, HyPr Touch (Hybrid Precision Touch) technology
Stands & Mounts
- Flat Panel Mount Interface
- 600 x 400 mm
Media Player
- USB Port
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Connectivity
- LAN, Bluetooth
- Connector Type
- 2 x HDMI input , VGA input , Audio line-out , SPDIF output , Audio line-in , 4 x USB 2.0 , 3 x USB , 2 x RS-232 , DisplayPort input
- Cables Included
- USB cable
- UL, cUL, FCC, RoHS, WEEE, REACH, RCM, TRA, HDCP 2.2, HDCP 1.4, ISED, LV, RED, CITIC, CONEG
Sustainability Information
- ENERGY STAR Certified
- Power Device
- Power supply
- Input Voltage
- 2 Watt
- Limited warranty - 3 years
- Width (Shipping)
- 191.6 cm
- Depth (Shipping)
- 30 cm
- Height (Shipping)
- 137.8 cm
- Weight (Shipping)
- 103 kg
- 5 °C
- 35 °C
- 5 - 80% (non-condensing)
