Smart Technologies 65" Interactive Flat Panel 16:9 3 Year Warranty
Installation required? Contact us today!
Quicklinx: CVJNWS00 Mfr#: DKTG
The SMART Board® 6065-V2 interactive flat panel with iQ is the hub of your classroom. iQ technology connects devices, lesson content and pedagogically relevant software to create a cohesive educational experience. PC-free embedded computing provides one-touch access to a diverse suite of SMART applications Notebook lessons, amp workspaces, lab gamification activities and whiteboard—and collaborative tools, such as wireless screen sharing and a web browser. There’s no need for wires, cables or manual software and firmware updates. The 65" 4K ultra-high-definition LED display provides optimal image clarity and wide viewing angles. With the Pen ID™ feature, you can assign different appearances to the two pens and write or draw over any application in digital ink. Object Awareness™ allows you to perform mouse functions with your finger, write in digital ink with the pen, and erase with your palm or eraser—all without switching tools or modes. You can use a variety of gestures in applications, and two users can write or draw at the same time.
The high-definition display features low-friction coated glass that lets fingers glide smoothly over the surface, creating a natural touch experience. The SMART Board 4065 interactive flat panel virtually eliminates glare and provides an optimal view from any angle in the classroom. It delivers an unparalleled viewing and writing experience, and offers the best value for classrooms. With eight simultaneous touch points for Windows, multiple students can use gestures, like zoom, rotate and flip, at the same time.
SMART Board 6265-V2 interactive flat panel with iQ 65" Class (64.5" viewable) LED display
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
65"
Diagonal Size
64.5"
Commercial Use
Yes - interactive
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
DisplayPort
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
Speaker System
2 speakers
USB
Voltage
110 Watt
Power Consumption Stand by
2.2 Watt
150.8 cm x 12 cm x 97.8 cm
60.9 kg
3-year warranty
110 Watt
Diagonal Class
65"
Diagonal Size
64.5"
Commercial Use
Yes - interactive
Combined With
Touchscreen
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
DisplayPort
150.8 cm
12 cm
97.8 cm
60.9 kg
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
1200:1
Brightness
338 cd/m²
Viewing Angle
178 degrees
Touchpoints Qty
8
Digital Vision Touch technology
Stands & Mounts
VESA Mounting Interface
300 x 400 mm
Media Player
USB Port
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
2 x HDMI input - side , 3 x USB 2.0 - side , Audio line-out - side , DisplayPort - side , Serial - side , USB 2.0 - bottom
2 touch pens, SMART Notebook software, iQ appliance
USB cable
UL, CCC, IC, FCC, RoHS, WEEE, PSE Mark, REACH, KC, EAC, RCM, SPRING
Power supply
Nominal Voltage
2.2 Watt
Limited warranty - 3 years
Width (Shipping)
175.8 cm
Depth (Shipping)
30.3 cm
Height (Shipping)
126.1 cm
Weight (Shipping)
82.1 kg
5 °C
35 °C
5 - 80% (non-condensing)
Resources
The following resources are available for the Smart Technologies 65" Interactive Flat Panel 16:9 3 Year Warranty
