Skullcandy Sesh Evo True Wireless In-Ear Headphones - Blue
Quicklinx: G02YWS00 Mfr#: S2TVW-N743
TRULY WIRELESS. PERFECTLY SIMPLE.
Sesh® Evo True Wireless Earbuds
THE JOY OF SESH. AND THEN SOME.
Sesh Evo makes it easier than ever to go truly wireless. With extended battery life, an impressive set of controls and our Fearless Use Promise®, there’s no reason to hold back.
HOURS (AND HOURS) OF POWER.
The buds themselves hold up to 5 hours, and the case charges the buds 3 times between plug-ins. Plus, with Rapid Charge, the first 10 minutes of charging give you 2 hours of play time.
WATER RESISTANT, WORRY-PROOF.
Sesh Evo boasts an IP55 rating for sweat, water and dust resistance. And with the Skullcandy Fearless Use Promise®, if anything ever happens to a bud or the case, we’ll replace it at a discount.
NEVER LOST WITH TILE.
Built-in Tile™ technology makes it easy to track down either earbud if you ever misplace them. Download the Tile app and follow the instructions to activate.
EASY CONNECTIONS AND CONTROLS.
Sesh Evo automatically enters pairing mode the first time they power on. And after that, they’ll auto-pair with the last device you used. Easy controls let you adjust volume, skip tracks, take calls, activate an assistant and even select different EQ modes without ever touching your phone.
Skullcandy Sesh Evo - true wireless earphones with mic
True wireless earphones - Bluetooth
Recommended Use
Portable electronics
Bleached blue
Headphones Form Factor
In-ear
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.0
Diaphragm Type
Titanium
Controls
Volume control, answer/end, next/previous track, voice assistant
True wireless earphones - Bluetooth - wireless
Bleached blue
Recommended Use
Protection
Dust-resistant, sweat-resistant, water-resistant, IP55
Audio Output
In-ear
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.0
Diaphragm
Titanium
Microphone
Built-in
Remote Control
Controls
Cable Details
USB-C charge cable
Headphone battery rechargeable
Run Time (Up To)
5 hour(s)
Run Time Details
(with included charging case): up to 24 hours
