TRUE FREEDOM, EFFORTLESS CHARGING.
CHARGE THE CASE WITHOUT WIRES.
True wireless means no wires. And, with Indy Fuel, even the case can charge wirelessly. Just drop it on your favorite wireless charging pad (or pair it with one of our Fuelbase™ series of chargers). Together, the case and buds hold up to 30 hours of total play time.
USE EITHER BUD BY ITSELF.
Sometimes, you just want to use one earbud, while you keep your other ear free to hear what’s around you. No problem. With Indy Fuel, you can use either the left or right earbud solo.
CONTROL WITHOUT YOUR PHONE.
A simple series of touches control everything directly from your buds. Answer calls, skip tracks, adjust volume, activate an assistant, switch EQ modes, even turn on Ambient Mode to hear more of your surroundings—all without ever touching your device.
NEVER LOST WITH TILE.
Built-in Tile™ technology makes it easy to track down either earbud if you ever misplace them. Download the Tile app and follow the instructions to activate.
DURABLE AND REPLACEABLE.
Indy Fuel earbuds are resistant to water, sweat and dust. And just in case any part is lost or damaged, our Fearless Use Promise® means we’ll replace it at a discount.
Charge the case without wires
True wireless means no wires. And, with Indy Fuel, even the case can charge wirelessly. Just drop it on your favorite wireless charging pad. Together, the case and buds hold up to 30 hours of total play time. -
Use either bud by itself
Sometimes, you just want to use one earbud, while you keep your other ear free to hear what's around you. No problem. With Indy Fuel, you can use either the left or right earbud solo. -
Control without your phone
A simple series of touches control everything directly from your buds. Answer calls, skip tracks, adjust volume, activate an assistant, switch EQ modes, even turn on Ambient Mode to hear more of your surroundings - all without ever touching your device. -
Never lost with Tile
Built-in Tile technology makes it easy to track down either earbud if you ever misplace them. -
Durable and replaceable
- Skullcandy Indy Fuel - true wireless earphones with mic
- Product Type
- True wireless earphones - Bluetooth
- Recommended Use
- Portable electronics
- Chill grey
- Headphones Form Factor
- In-ear
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 5.0
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz
- Impedance
- 32 Ohm
- 2-year warranty
- Product Type
- True wireless earphones - Bluetooth - wireless
- 57 g
- Chill grey
- Recommended Use
Audio Output
- In-ear
- Connectivity Technology
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 5.0
- Sound Output Mode
- Stereo
- 20 - 20000 Hz
- Total Harmonic Distortion (THD)
- <3%
- Impedance
- 32 Ohm
- Diaphragm
- 6 mm
Microphone
- Form Factor
- Built-in
- Included Accessories
- Charging case, 3 pairs of EarGels, USB-C charging cable
- Battery
- Headphone battery rechargeable
- Run Time Details
- Continuous playback (with included charging case): up to 30 hours
- Limited warranty - 2 years
