Sharp's multi-purpose, user-friendly PN-Y425 LED display delivers your message with the eye-catching impact of Full HD resolution. Sized to match a wide variety of installation locations, this professional monitor performs equally well in public areas, offices, and retail spaces, whether in a landscape or a portrait orientation. A built-in USB media player supports playback of both still images and videos and allows the PN-Y425 to be used as a standalone signage solution even in the absence of a PC or network connection.
- Sharp PN-Y425 PN-Y Series - 42" LED-backlit LCD display - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 42"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1920 x 1080
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- Technology
- UV²A
- LCD Backlight Technology
- Edge-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- USB
- Voltage
- AC 120/230 V (50/60 Hz)
- 120 Watt
- Power Consumption Stand by
- 0.5 Watt
- Dimensions (WxDxH) - without stand
- 96.8 cm x 6.6 cm x 56.1 cm
- 14.4 kg
- Product Type
- 120 Watt
- Diagonal Class
- 42"
- Commercial Use
- Series
- PN-Y Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- Modes
- Portrait mode, landscape mode, Mirror Display Mode
- Design
- Slim Bezel Design
- Cooling System
- Fanless
- Dimensions
- Without stand
- 96.8 cm
- 6.6 cm
- 56.1 cm
- 14.4 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- UV²A
- Resolution
- 1920 x 1080
- 16:9
- Edge-lit LED
- Colour Depth
- Up to 1.06 billion colours
- Image Contrast Ratio
- 1300:1
- Brightness
- 450 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 12 ms
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 400 mm
Media Player
- USB Port
- USB Ports Qty
- 1
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 14 Watt
- Speakers
- 2 x main channel speaker - 7 Watt
- Connector Type
- HDMI input - rear , DVI-D input - rear , DVI-D output - rear , LAN - rear , Component video / composite video / VGA input - rear , USB - rear , Serial input - rear , Serial output - rear , Audio line-in - rear , Audio line-out - rear , Audio line-in - rear
- Plug and Play
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- On / Off Switch
- 0 °C
- 40 °C
- 20 - 80%
