Product
Brand
Sharp PNY425 42" 1920x1080 USB LED LFD
Quicklinx: 9VNPWS00 Mfr#: PNY425
  • 1080p (Full HD)
Sharp's multi-purpose, user-friendly PN-Y425 LED display delivers your message with the eye-catching impact of Full HD resolution. Sized to match a wide variety of installation locations, this professional monitor performs equally well in public areas, offices, and retail spaces, whether in a landscape or a portrait orientation. A built-in USB media player supports playback of both still images and videos and allows the PN-Y425 to be used as a standalone signage solution even in the absence of a PC or network connection.
Sharp PN-Y425 PN-Y Series - 42" LED display
LED-backlit LCD flat panel display
Diagonal Class
42"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Component, composite, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
UV²A
LCD Backlight Technology
LED backlight - edge-lit
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB
Voltage
120 Watt
96.8 cm x 6.6 cm x 56.1 cm
14.4 kg
120 Watt
Diagonal Class
42"
Commercial Use
Series
PN-Y Series
TV Tuner
No tuner
Video Interface
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Modes
Portrait mode, landscape mode, Mirror Display Mode
Design
Slim Bezel Design
Cooling System
Fanless
Dimensions
Without stand
96.8 cm
6.6 cm
56.1 cm
14.4 kg
Enclosure Colour
Display
LCD Display Technology
UV²A
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Colour Depth
Up to 1.06 billion colours
Image Contrast Ratio
1300:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
12 ms
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
Media Player
USB Port
USB Ports Qty
1
Audio System
Speaker System
2 speakers
Output Power / Total
14 Watt
Speakers
2 x main channel speaker - built-in - 7 Watt
Connector Type
HDMI input - rear , DVI-D input - rear , DVI-D output - rear , Network - rear , Component video / composite video / VGA input - rear , USB - rear , Serial input - rear , Serial output - rear , Audio line-in - rear , Audio line-out - rear , Audio line-in - rear
Plug and Play
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
On / Off Switch
20 - 80%
