Sharp PNV601(A) 60" 1366x768 HDMI LED Large Format Display
Installation required? Contact us today!
Quicklinx: 9J2RWS00 Mfr#: PNV601(A)
TV Tuner Presence: No
Video Interface: HDMI
£4,426.47 ex VAT
£5,311.76 inc VAT
The PN-V601A ultra thin bezel model is mainly designed for video wall applications. This 152 cm (60") LCD-monitor can be used in a variety of signage and multi screen configurations. As a flexible solution with an almost seamless bezel, the PN-V601A sets a new standard for video wall displays.
  • Enlarge display mode
    The Enlarge Display mode can spread one image across up to 25 monitors from a PC. The Frame Width Adjustment function virtually eliminates misalignment and boldly enhances the enlarged image on a multi-screen display.
  • Full-array LED backlight
    To give the PN-V601A more uniform brightness than conventional CCFL backlighting can offer, Sharp has positioned LED elements across the entire panel directly behind the liquid crystal layers, helping ensure that Sharp multi-screen displays are bright, beautiful and uniform.
  • Professional quality and 24/7 durability
    Because business never stops, neither do the PN-V601A video wall monitors. These professional-grade products are rugged enough for continuous 24/7 operation in the most demanding professional applications.
  • Full range of connectivity
    The PN-V601A feature extensive interface capability.
  • Create a 4K2K ultra-high resolution experience
    When placed in a 3x3 video wall configuration, the PN-V601A standard resolution multiplies by three, creating a total resolution of up to 4098 x 2304 pixels for ultra-high resolution/ultra-high impact images.
Sharp PN-V601A PN-V Series - 60" LED display
LED-backlit LCD flat panel display
Diagonal Class
60"
Commercial Use
Yes - digital signage
Resolution
1366 x 768
Display Format
720p
Video Wall Components Qty
25
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight - direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Voltage
480 Watt
133.59 cm x 14.93 cm x 75.42 cm
45 kg
480 Watt
Diagonal Class
60"
Commercial Use
Series
PN-V Series
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Brightness sensor
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15)
HDCP Compatible
Modes
Portrait mode, landscape mode, Mirror Display Mode
25
Dimensions
Without stand
133.59 cm
14.93 cm
75.42 cm
45 kg
Display
Resolution
1366 x 768
Display Format
720p
Image Aspect Ratio
16:9
Colour Depth
16.7 million colours
Image Contrast Ratio
4000:1
Brightness
700 cd/m²
Viewing Angle
176 degrees
Viewing Angle (Vertical)
176 degrees
Response Time
6 ms
Certified for 24/7 Continuous Operation, Hardware Diagnostics, Bezel Correction
Stands & Mounts
VESA Mounting Interface
200 x 200 mm
Connector Type
HDMI input - rear , VGA input - rear , Audio line-in - rear , Audio line-out - rear , Serial input - rear , Serial output - rear , Remote control - rear
Plug and Play
Power supply
Nominal Voltage
On / Off Switch
20 - 80%
Brand: Sharp
Price Range Ex VAT: 1500+
