Sharp PNV600(A) 60" 1366x768 HDMI LED Large Format Display
Quicklinx: 9J2QWS00 Mfr#: PNV600(A)
Designed for sophisticated video wall applications, the PN-V600A video wall monitor offers the world's slimmest bezel available on a 60" class (60" diagonal) LCD display. As a flexible digital signage solution with 24/7 certified reliability and an almost seamless bezel (just 6.5 mm total between neighboring monitors), the PN-V600A helps set a great standard for video wall displays. Its full-array LED backlight helps ensure uniform brightness and an enlarge (zoom) display mode enables one image to be expanded across up to 25 monitors (in a 5x5 configuration). An optional PN-ZR01 Control Kit permits all monitors in a video wall to be operated using a single remote.
  • Enlarge (zoom) display mode (for up to 25 monitors)
    The Enlarge (zoom) display mode can spread one image across up to 25 monitors (in a 5 x 5 configuration) from a PC. The Frame Width Adjustment function virtually eliminates misalignment and boldly enhances the enlarged image on a multi-screen display.
  • Full-array LED backlight
    To give the PN-V600A more uniform brightness than conventional CCFL backlighting can offer, Sharp has positioned LED elements across the entire panel directly behind the liquid crystal layers, helping ensure that Sharp multi-screen displays are bright, beautiful and uniform.
  • Almost limitless display possibilities
    Thanks to the PN-V600A A's ultra-slim bezel, the borders between neighboring monitors are a virtually seamless 6.5 mm"1 wide (2.4 mm on the right and bottom; 4.1 mm on the left and top)." When used in a video wall configuration, this enables the display of crisp and high impact images of almost any size and format. With 24/7 certified reliability and 3-year onsite parts, the PN-V600 is designed to be both exceptionally reliable and environmentally friendly.
  • Professional quality and 24/7 durability
    Because business never stops, neither do the PN-V600A video wall monitors. This professional-grade product is rugged enough for continuous 24/7 operation in the most demanding professional applications.
  • Full range of connectivity
    The PN-V600A features extensive interface capability.
  • Create a 4K2K ultra-high resolution experience
    When placed in a 3x3 video wall configuration, the PN-V600A standard resolution multiplies by three, creating a total resolution of up to 4098 x 2304 pixels for ultra-high resolution/ultra-high impact images.
Sharp PN-V600A PN-V Series - 60" LED-backlit LCD display - HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
60"
Commercial Use
Yes - digital signage
Resolution
1366 x 768
Display Format
720p
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15)
HDCP Compatible
UV²A
LCD Backlight Technology
Direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Voltage
310 Watt
Power Consumption Stand by
1 Watt
133.59 cm x 14.93 cm x 75.42 cm
41 kg
310 Watt
Diagonal Class
60"
Commercial Use
Series
PN-V Series
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Brightness sensor
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15)
HDCP Compatible
Modes
Portrait mode, landscape mode, Mirror Display Mode
Dimensions
Without stand
133.59 cm
14.93 cm
75.42 cm
41 kg
Display
LCD Display Technology
UV²A
Resolution
1366 x 768
Display Format
720p
Image Aspect Ratio
16:9
Direct-lit LED
Colour Depth
16.7 million colours
Image Contrast Ratio
4000:1
Brightness
450 cd/m²
Viewing Angle
176 degrees
Viewing Angle (Vertical)
176 degrees
Response Time
6 ms
Certified for 24/7 Continuous Operation, Hardware Diagnostics, Bezel Correction
Stands & Mounts
Flat Panel Mount Interface
200 x 200 mm
Connector Type
HDMI input - rear , VGA input - rear , Audio line-in - rear , Audio line-out - rear , Serial input - rear , Serial output - rear , Remote control - rear
Plug and Play
Power supply
Input Voltage
1 Watt
On / Off Switch
20 - 80%
