Sharp PNU553 55" 1920x1080 DVI HDMI DisplayPort LED Large Format Display
Quicklinx: 9J2HWS00 Mfr#: PNU553
TV Tuner Presence: No
Video Interface: Component, HDMI
  • 1080p (Full HD)
£1,728.93 ex VAT
£2,074.71 inc VAT
A brightness of 700 cd/m2 PN-U553 supports these LCD monitors in their digital signage duties. And PN-U553 monitors boast 1,920 (H) x 1,080 (V)-pixel full-HD resolution to ensure that none of the detail or visual impact is lost. Thanks to Full-HD resolution, everything from fine text to intricate graphics is stunningly crisp and clear.
PN-U553 monitor owes its exceptionally thin profiles to edge-lit LED backlighting, where LED elements are located at the edges of the panel. The stylishly thin profiles also enable attractive wall mounting.
  • Excellent image quality
  • Thin, lightweight design
  • Energy efficiency
    Edge-lit LED backlighting on PN-U553 monitor helps ensure reliable performance with low power consumption. In fact, PN-U553 monitor consumes significantly less energy than conventional CCFL-backlight displays.
  • Choice of installation mode
    PN-U553 monitor offers a choice of landscape or portrait installation, allowing customers to select the mode that best suits their display content and application. While portrait installation offers the look and impact of a poster, landscape installation puts wide images on vivid display.
  • Enlarge (zoom) display mode
    Multiple monitors can be grouped together to display one enlarged image, thanks to enlarge (zoom) display mode, which corrects the framing of that image to eliminate misalignment between monitors.
  • Built-in speakers
    Ideal for conveying audio information and playing location-appropriate background music, PN-U553 monitor features built-in 10 W + 10 W rear speakers that eliminate the need for external speakers and ensure a stylishly streamlined profile.
  • Expanded connectivity
    A comprehensive range of input/output terminals, including the DisplayPort interface, comes as standard on PN-U553 monitor to give customers a variety of connection possibilities.
  • Power on delay
    The power on delay function allows a time delay between the startup of each monitor in multi-monitor installations. This reduces the load placed on the power supply when a number of monitors are turned on at the same time.
  • Fanless architecture
    Fanless architecture maintains airflow and dissipates heat without the use of mechanical air-ventilation fans, which can attract dust and create noise. This fanless design also facilitates monitor maintenance.
  • Built-in temperature sensor
    Should the temperature inside a monitor rise, a built-in sensor will detect it, and the monitor will automatically lower the brightness level of its backlight system.
Sharp PN-U553 PN series - 55" LED display
LED-backlit LCD flat panel display
Diagonal Class
55"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
480p, 720p, 1080i, 1080p, 480i, 576i, 576p, 1080/24p
Video Interface
Component, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
UV²A
LCD Backlight Technology
LED backlight - edge-lit
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
AC 120/230 V
130 Watt
125 cm x 5.7 cm x 72.1 cm
25 kg
130 Watt
Diagonal Class
55"
Commercial Use
Series
PN series
TV Tuner
No tuner
Video Interface
Component, HDMI
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Modes
Portrait mode, landscape mode
Dimensions
Without stand
125 cm
5.7 cm
72.1 cm
25 kg
Display
LCD Display Technology
UV²A
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Colour Depth
Up to 1.06 billion colours
Image Contrast Ratio
4000:1
Brightness
700 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
6.5 ms
Split screen, Certified for 24/7 Continuous Operation, Ultraviolet-induced Multi-domain Vertical Alignment technology (UV2A), Data Signal Power Auto (DSPA)
Stands & Mounts
Flat Panel Mount Interface
400 x 200 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1024 x 768 (XGA), 800 x 600 (SVGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 1280 x 800, 1400 x 1050
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
Serial input , Network , HDMI input , DisplayPort input , DVI-D input , DVI-D output , VGA / component video input , Audio line-in , Component video input , Audio line-in , Audio line-out
Power supply
Nominal Voltage
AC 120/230 V
Power Consumption Stand by
4.5 Watt
Video Interface: HDMI
Brand: Sharp
Price Range Ex VAT: 1500+
