Your basket is empty
Sharp PNU423 42" 1920x1080 DVI HDMI DisplayPort LED Large Format Display
Quicklinx: 9J2FWS00 Mfr#: PNU423
  • 1080p (Full HD)
A brightness of 500 cd/m2 (PN-U423) supports these LCD monitors in their digital signage duties. And PN-U423 monitor boasts 1,920 (H) x 1,080 (V)-pixel full-HD resolution to ensure that none of the detail or visual impact is lost. Thanks to Full-HD resolution, everything from fine text to intricate graphics is stunningly crisp and clear.
PN-U423 monitor owes its exceptionally thin profiles to edge-lit LED backlighting, where LED elements are located at the edges of the panel. The stylishly thin profiles also enable attractive wall mounting.
Sharp PN-U423 42" LED display
LED-backlit LCD flat panel display
Diagonal Class
42"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
480p, 720p, 1080i, 1080p, 480i, 540p, 576i, 576p, 1080/24p
Video Interface
Component, HDMI
LAN
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
UV²A
LCD Backlight Technology
LED backlight - edge-lit
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
AC 120/230 V
115 Watt
97.3 cm x 5.7 cm x 56.5 cm
16 kg
115 Watt
Diagonal Class
42"
Commercial Use
TV Tuner
No tuner
Video Interface
Component, HDMI
PC Interface
HDCP Compatible
Modes
Portrait mode, landscape mode
Dimensions
Without stand
97.3 cm
5.7 cm
56.5 cm
16 kg
Display
LCD Display Technology
UV²A
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Colour Depth
Up to 1.06 billion colours
Image Contrast Ratio
4000:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Split screen, Certified for 24/7 Continuous Operation, Data Signal Power Auto (DSPA)
Stands & Mounts
Flat Panel Mount Interface
400 x 200 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1024 x 768 (XGA), 800 x 600 (SVGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 1280 x 800, 1400 x 1050
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
LAN
Connector Type
DVI-D input , HDMI , VGA input , DVI-I , Component video input , Serial , Network , Audio line-in , Audio line-in , Audio line-out
Power supply
Nominal Voltage
AC 120/230 V
Power Consumption Stand by
0.5 Watt
