Sharp PNR703 70" 1920x1080 DVI HDMI DisplayPort LED Large Format Display
Installation required? Contact us today!
Quicklinx: 9J2WWS00 Mfr#: PNR703
  • 1080p (Full HD)
With its 70" class screen size, 24/7 reliability and energy efficient edge lit LED backlight, the PN-R703 is designed to meet the rigors of most any commercial display or digital signage application. Add to this Sharp's UV2A photo alignment technology, full 1920 x 1080 HD resolution, and optional media player, and you have one of the highest performing and most flexible displays in the industry. For versatility, performance and value, there's never been a better time to think BIG - and think Sharp.
  • 70" class
    Combined with Sharp UV2A photo alignment technology help create brilliant color images with maximum impact.
  • Edge-Lit LED backlight
    Reduces power consumption and helps enhance reliability and legibility of text.
  • Brilliant, big screen images for digital signage
    For use in public areas like trade show exhibit halls, hotel lobbies and conference areas, airport corridors and retail locations.
  • Engineered for 24/7 commercial use
    Provides the reliability and durability you need for virtually any business.
  • Full 1920 x 1080 (1080p) resolutions
    From analog RGB, digital RGB and HDTV video sources.
  • Built-in 10 W per channel stereo speakers
    Eliminates need for an external audio system for many installations.
  • Extensive interface capability
    Includes as standard interfaces HDMI input x2, D-Sub 15-pin RGB input, RS-232C input/output, DVI-I input, DVI-D output, DisplayPort input/output, stereo audio (1/8") input x 2, stereo audio (1/8") output, and RJ-45 LAN display control.
Sharp PN-R703 70" LED display
LED-backlit LCD flat panel display
Diagonal Class
70"
Commercial Use
Yes - digital signage
Country Kits
Europe
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
480p, 720p, 1080i, 1080p, 480i, 540p, 1035i, 576i, 576p, 1080/24p
Video Interface
HDMI
LAN
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight - full array
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
AC 120/230 V
Energy Class
Class A
270 Watt
Power Consumption Stand by
0.5 Watt
157.8 cm x 3.94 cm x 91.6 cm
43 kg
Energy Class
Class A
270 Watt
Diagonal Class
70"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Modes
Portrait mode, landscape mode
Dimensions
Without stand
157.8 cm
3.94 cm
91.6 cm
43 kg
Country Kits
Europe
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Colour Depth
Up to 1.06 billion colours
Image Contrast Ratio
4000:1
Brightness
700 cd/m²
Viewing Angle
176 degrees
Viewing Angle (Vertical)
176 degrees
Response Time
6 ms
Split screen, Certified for 24/7 Continuous Operation, UV 2 A technology
Stands & Mounts
VESA Mounting Interface
Video Features
Analogue Video Input Signals
PAL, SECAM, NTSC 3.58, NTSC4.43, PAL-M, PAL-N, PAL60
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1024 x 768 (XGA), 800 x 600 (SVGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 1280 x 800, 1400 x 1050
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
LAN
Connector Type
DVI-D input , DVI-D output , HDMI , VGA input , Serial , Network , Audio line-in , Audio line-out
Power supply
Nominal Voltage
AC 120/230 V
0.5 Watt
