With its 60" class diagonal screen size, 24/7 reliability and energy efficient edge lit LED backlight, the PN-R603 is designed to meet the rigors of most any commercial display or digital signage application. Add to this Sharp's UV2A photo alignment technology, full 1920 x 1080 HD resolution, and optional media player, you have one of the highest performing and most flexible displays in the industry. For versatility, performance and value, there's never been a better time to think BIG - and think Sharp.
60" class (60 1/16" diagonal)
Combined with Sharp UV2A photo alignment technology help create brilliant color images with maximum impact. -
Edge-Lit LED backlight
Reduces power consumption and helps enhance reliability and legibility of text. -
Brilliant, big screen images for digital signage
For use in public areas like trade show exhibit halls, hotel lobbies and conference areas, airport corridors and retail locations. -
Engineered for 24/7 commercial use
Provides the reliability and durability you need for virtually any business. -
Full 1920 x 1080 (1080p) resolutions
From analog RGB, digital RGB and HDTV video sources. -
Built-in 10 W per channel stereo speakers
Eliminates need for an external audio system for many installations. -
Extensive interface capability
Includes as standard interfaces HDMI input x2, D-Sub 15-pin RGB input, RS-232C input/output, DVI-I input, DVI-D output, DisplayPort input/output, stereo audio (1/8") input x 2, stereo audio (1/8") output, and RJ-45 LAN display control.
- Sharp PN-R603 60" LED-backlit LCD display - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 60"
- Commercial Use
- Yes - digital signage
- Country Kits
- Europe
- Resolution
- 1920 x 1080
- Input Video Formats
- 480p, 720p, 1080i, 1080p, 480i, 540p, 1035i, 576i, 576p, 1080/24p
- Video Interface
- HDMI
- Connectivity
- LAN
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- LCD Backlight Technology
- Edge-lit LED
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V
- Energy Class
- Class A
- 200 Watt
- Power Consumption Stand by
- 0.5 Watt
- Dimensions (WxDxH) - without stand
- 137.8 cm x 3.94 cm x 79.4 cm
- 32 kg
- Product Type
- Energy Class
- Class A
- 200 Watt
- Diagonal Class
- 60"
- Commercial Use
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- Modes
- Portrait mode, landscape mode
- Dimensions
- Without stand
- 137.8 cm
- 3.94 cm
- 79.4 cm
- 32 kg
- Country Kits
- Europe
Display
- Resolution
- 1920 x 1080
- Edge-lit LED
- Colour Depth
- Up to 1.06 billion colours
- Image Contrast Ratio
- 4000:1
- Brightness
- 700 cd/m²
- Viewing Angle
- 176 degrees
- Viewing Angle (Vertical)
- 176 degrees
- Response Time
- 6 ms
- Split screen, Certified for 24/7 Continuous Operation
Stands & Mounts
- Flat Panel Mount Interface
Video Features
- Analogue Video Input Signals
- PAL, SECAM, NTSC 3.58, NTSC4.43, PAL-M, PAL-N, PAL60
- Supported Computer Resolutions
- 1366 x 768, 1024 x 768 (XGA), 800 x 600 (SVGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 1280 x 800, 1400 x 1050
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Connectivity
- LAN
- Connector Type
- DVI-D input , DVI-D output , HDMI , VGA input , Serial , LAN , Audio line-in , Audio line-out
- Power Device
- Power supply
- Input Voltage
- AC 120/230 V
- 0.5 Watt
