Product
Sharp PNK322BH 32" 3840x2160 4K DisplayPort 10 Point Touch LED Large Format Display
Quicklinx: 9J2DWS00 Mfr#: PNK322BH
At 3840 x 2160 pixels (QFHD), this 80.1 cm diagonal (32" class) touch monitor boasts four times the resolution of 1080p Full HD. Users can now view the content of four HD screens on a single, seamless display. The PN-K322BH goes a step further to add multi-touch touch screen capability to the ultra-HD monitor to further expand possible applications.
Sharp PN-K322BH - LED monitor - 32"
LED-backlit LCD monitor - 32" - touchscreen
Energy Class
Class A
Touch-screen
Aspect Ratio
16:9
Native Resolution
4K UHD (2160p) 3840 x 2160
Brightness
300 cd/m²
Contrast Ratio
800:1
Response Time
8 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
DisplayPort
Speakers
Integrated
75 cm x 3.6 cm x 44.1 cm
9 kg
Display Type
Energy Class
Class A
Diagonal Size
32"
Aspect Ratio
16:9
Native Resolution
Pixel Per Inch
140
Brightness
300 cd/m²
Contrast Ratio
800:1
Colour Support
Response Time
8 ms (grey-to-grey)
Horizontal Viewing Angle
176
Vertical Viewing Angle
176
Backlight Technology
LED backlight
10-point multi-touch, IGZO technology
75 cm x 3.6 cm x 44.1 cm - without stand
9 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
Input
Touch-screen - touchscreen
Movement Detection Technology
Capacitive
DisplayPort , Serial , Headphones , USB , Audio line-in
Mechanical
Flat Panel Mount Interface
200 x 200 mm
Power Supply
Internal
97 Watt
Dimensions & Weight Details
Without stand - width: 75 cm - depth: 3.6 cm - height: 44.1 cm - weight: 9 kg
5 °C
35 °C
20 - 80%
