Sharp PN80TC3 80" 1920x1080 LED LFD
Quicklinx: BQJHWS00 Mfr#: PN80TC3
  • 1080p
Say goodbye to unintended input and writing errors. Thanks to the PN-80TC3's precise position detection, only intentional input from fingers and touch pens appears on the display. Employing Sharp's original capacitive touch technology - which achieves high sensitivity and precision by reducing the noise level - the PN-80TC3 eliminates unwanted noise to deliver a clear onscreen signal. The PN-80TC3 lets you capture ideas at the moment of creation. Recognizing up to 10 touch points, it allows up to four people to write at the same time with a finger or touch pen.
  • Simultaneous writing for up to 4 people
  • Featherlight touch for precise and smooth operation
  • Display, write, and share information
    In overlay mode, you can write onscreen annotations directly onto photos, videos, PDFs, and documents such as Microsoft Excel, Word, and PowerPoint. Text and graphics written on the board can be stored in USB memory or sent directly via e-mail to selected recipients.
  • Touch-operated onscreen display
    Pressing the Touch Menu button brings up an onscreen menu that lets you easily switch input sources, change volume level, or turn the touchscreen function on and off - all from the front of the PN-80TC3 and all without the need for a remote controller.
  • Supports installation of a web camera
    The PN-80TC3 supports installation of a web camera, giving you the flexibility to find the optimal set-up to match your room layout and seating arrangements.
  • A variety of input and output terminals
    The PN-80TC3 comes standard-equipped with a wealth of input and output terminals - located on the side and bottom of the monitor - to enable easy connection with a wide variety of equipment.
Sharp BIG PAD PN-80TC3 80" LED-backlit LCD display - Full HD - for interactive communication
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
80"
Commercial Use
Yes - interactive
Resolution
1920 x 1080
Display Format
1080p
Video Interface
Component, composite, HDMI
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15), DisplayPort
HDCP Compatible
UV²A
LCD Backlight Technology
LED backlight
TV Tuner
No tuner
Speaker System
2 speakers
Remote control, 2 AAA batteries, 2 AA batteries, eraser, Sharp Pen Software, pen tray, blank sticker, electronic touch pen, touch pen adapter, 7 x cable clamps
Voltage
280 Watt
185 cm x 9.6 cm x 107.2 cm
77 kg
280 Watt
Diagonal Class
80"
Commercial Use
Yes - interactive
Combined With
Touchscreen
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI Ports Qty
3 ports
PC Interface
HDCP Compatible
Modes
Whiteboard mode
Protection
Protection glass
Dimensions
Without stand
185 cm
9.6 cm
107.2 cm
77 kg
Display
LCD Display Technology
UV²A
Resolution
1920 x 1080
Display Format
1080p
LED backlight
Colour Depth
Up to 1.06 billion colours
Image Contrast Ratio
4000:1
Brightness
300 cd/m²
Viewing Angle
176 degrees
Viewing Angle (Vertical)
176 degrees
Pixel Pitch
0.923 x 0.923 mm
Touchpoints Qty
10
Response Time
4 ms
Infrared blocking detection, handwriting recognition
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Video Features
Analogue Video Input Signals
PAL, SECAM, NTSC 3.58, NTSC4.43, PAL60
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Connector Type
USB 2.0 , VGA input , 3 x HDMI input , 2 x audio line-in , Component video input , Composite video input , 2 x audio line-in , DisplayPort input , Serial input , DisplayPort output , Audio line-out , Speakers output
Plug and Play, DDC-2B
Power supply
Input Voltage
5 °C
35 °C
20 - 80% (non-condensing)
