Say goodbye to unintended input and writing errors. Thanks to the PN-80TC3's precise position detection, only intentional input from fingers and touch pens appears on the display. Employing Sharp's original capacitive touch technology - which achieves high sensitivity and precision by reducing the noise level - the PN-80TC3 eliminates unwanted noise to deliver a clear onscreen signal. The PN-80TC3 lets you capture ideas at the moment of creation. Recognizing up to 10 touch points, it allows up to four people to write at the same time with a finger or touch pen.
Simultaneous writing for up to 4 people
The PN-80TC3 lets you capture ideas at the moment of creation. Recognizing up to 10 touch points, it allows up to four people to write at the same time with a finger or touch pen. -
Featherlight touch for precise and smooth operation
Say goodbye to unintended input and writing errors. Thanks to the PN-80TC3's precise position detection, only intentional input from fingers and touch pens appears on the display. Employing Sharp's original capacitive touch technology - which achieves high sensitivity and precision by reducing the noise level - the PN-80TC3 eliminates unwanted noise to deliver a clear onscreen signal. -
Display, write, and share information
In overlay mode, you can write onscreen annotations directly onto photos, videos, PDFs, and documents such as Microsoft Excel, Word, and PowerPoint. Text and graphics written on the board can be stored in USB memory or sent directly via e-mail to selected recipients. -
Touch-operated onscreen display
Pressing the Touch Menu button brings up an onscreen menu that lets you easily switch input sources, change volume level, or turn the touchscreen function on and off - all from the front of the PN-80TC3 and all without the need for a remote controller. -
Supports installation of a web camera
The PN-80TC3 supports installation of a web camera, giving you the flexibility to find the optimal set-up to match your room layout and seating arrangements. -
A variety of input and output terminals
The PN-80TC3 comes standard-equipped with a wealth of input and output terminals - located on the side and bottom of the monitor - to enable easy connection with a wide variety of equipment.
- Sharp BIG PAD PN-80TC3 80" LED-backlit LCD display - Full HD - for interactive communication
- Product Type
- LED-backlit LCD flat panel display with touchscreen
- Diagonal Class
- 80"
- Commercial Use
- Yes - interactive
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 3 ports
- PC Interface
- VGA (HD-15), DisplayPort
- HDCP Compatible
- Technology
- UV²A
- LCD Backlight Technology
- LED backlight
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Included Accessories
- Remote control, 2 AAA batteries, 2 AA batteries, eraser, Sharp Pen Software, pen tray, blank sticker, electronic touch pen, touch pen adapter, 7 x cable clamps
- Voltage
- AC 120/230 V (50/60 Hz)
- 280 Watt
- Dimensions (WxDxH) - without stand
- 185 cm x 9.6 cm x 107.2 cm
- 77 kg
- Product Type
- 280 Watt
- Diagonal Class
- 80"
- Commercial Use
- Yes - interactive
- Combined With
- Touchscreen
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI Ports Qty
- 3 ports
- PC Interface
- HDCP Compatible
- Modes
- Whiteboard mode
- Protection
- Protection glass
- Dimensions
- Without stand
- 185 cm
- 9.6 cm
- 107.2 cm
- 77 kg
Display
- LCD Display Technology
- UV²A
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- LED backlight
- Colour Depth
- Up to 1.06 billion colours
- Image Contrast Ratio
- 4000:1
- Brightness
- 300 cd/m²
- Viewing Angle
- 176 degrees
- Viewing Angle (Vertical)
- 176 degrees
- Pixel Pitch
- 0.923 x 0.923 mm
- Touchpoints Qty
- 10
- Response Time
- 4 ms
- Infrared blocking detection, handwriting recognition
Stands & Mounts
- Flat Panel Mount Interface
- 600 x 400 mm
Video Features
- Analogue Video Input Signals
- PAL, SECAM, NTSC 3.58, NTSC4.43, PAL60
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
- Connector Type
- USB 2.0 , VGA input , 3 x HDMI input , 2 x audio line-in , Component video input , Composite video input , 2 x audio line-in , DisplayPort input , Serial input , DisplayPort output , Audio line-out , Speakers output
- 2 AAA batteries, 2 AA batteries, eraser, Sharp Pen Software, pen tray, blank sticker, electronic touch pen, touch pen adapter, 7 x cable clamps
- Plug and Play, DDC-2B
- Power Device
- Power supply
- Input Voltage
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
