The Sharp BIG PAD PN-70SC3 is the ideal model for higher education campuses and corporate office applications. Offering state-of-the-art collaboration with outstanding price performance, Sharp’s next generation 70" BIG PAD is optimized for the campus and SME environment to enhance communication and create the best conditions for effective collaboration.
Whether in a classroom or a meeting room, it can sometimes be a challenge to keep everyone focused and engaged. That's where Sharp's innovative BIG PAD PN-70SC3 comes in. The generous Full HD 70" touchscreen monitor lets you display, create and collaborate with ease and precision.
The acclaimed, smart and intuitive pen software opens up new ways for brainstorming, sharing ideas and finalizing decisions. Powerful, flexible and surprisingly cost-effective, the latest Sharp BIG PAD PN-70SC3 provides an outstanding platform to either boost collaboration, enhance audience impact, or simply increase meeting effectiveness in the corporate office or campus environment.
- Sharp BIG PAD PN-70SC3 70" Class (69.5" viewable) LED-backlit LCD display - for interactive communication
- Product Type
- LED-backlit LCD flat panel display with touchscreen
- Diagonal Class
- 70"
- Diagonal Size
- 69.5"
- Commercial Use
- Yes - interactive
- Resolution
- 1920 x 1080
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 3 ports
- PC Interface
- VGA (HD-15)
- HDCP Compatible
- Technology
- UV²A
- LCD Backlight Technology
- Edge-lit LED
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Included Accessories
- Remote control, 2 AA batteries, eraser, 2 x cable clamps, Sharp Pen Software, pen tray, blank sticker, electronic touch pen
- Voltage
- AC 120/230 V (50/60 Hz)
- 235 Watt
- Dimensions (WxDxH) - without stand
- 163.3 cm x 10.9 cm x 99.45 cm
- 56 kg
- Product Type
- 235 Watt
- Diagonal Class
- 70"
- Diagonal Size
- 69.5"
- Commercial Use
- Yes - interactive
- Combined With
- Touchscreen
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI Ports Qty
- 3 ports
- PC Interface
- VGA (HD-15)
- HDCP Compatible
- Modes
- Whiteboard mode
- Protection
- Protection glass
- Dimensions
- Without stand
- 163.3 cm
- 10.9 cm
- 99.45 cm
- 56 kg
Display
- LCD Display Technology
- UV²A
- Resolution
- 1920 x 1080
- Edge-lit LED
- Colour Depth
- 16.8 million colours
- Image Contrast Ratio
- 3000:1
- Brightness
- 300 cd/m²
- Viewing Angle
- 160 degrees
- Viewing Angle (Vertical)
- 160 degrees
- Pixel Pitch
- 0.802 x 0.802mm
- Touchpoints Qty
- 6
- Response Time
- 6 ms
- Infrared blocking detection, handwriting recognition, Certified for 16/7 Continuous Operation
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 400 mm
Video Features
- Analogue Video Input Signals
- PAL, SECAM, NTSC 3.58, NTSC4.43, PAL60
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Connector Type
- USB 2.0 , VGA input , 3 x HDMI input , Audio line-in , Component video input , Composite video input , 2 x audio line-in , Audio line-out , Serial input
- 2 AA batteries, eraser, 2 x cable clamps, Sharp Pen Software, pen tray, blank sticker, electronic touch pen
- Cables Included
- USB cable
- Plug and Play, DDC-2B
- Power Device
- Power supply
- Input Voltage
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
