Sharp PN-E703 70" 1920x1080 LED LFD
Quicklinx: BQJKWS00 Mfr#: PN-E703
TV Tuner Presence: No
Video Interface: HDMI
  • 1080p (Full HD)
Hurry, only 2 left in stock!
£2,955.88 ex VAT
£3,547.05 inc VAT
These 70-inch-class (69.5" diagonal) Sharp monitos combines Full-HD image quality, stylishly thin profiles and energy efficiency to create appealing professional signage solutions for a wide range of applications. With their sleek design, around-the-clock operation, and support for landscape and portrait installations, this display offers an amazing degree of flexibility. In hotel lobbies, conference rooms, retail spaces and elsewhere, the PN-E703 will grab and keep the attention of your target audience.
  • Superb image quality
    PN-E703 panel incorporates Sharp's technology, which prevents light leakage and ensures highly efficient use of light from the backlight. Thanks to this technology, the monitor achieves truly bright whites and extremely deep blacks. This model supports full-HD (1080p) resolution, for beautifully clear rendering of detailed text and graphics.
  • Thin, lightweight design
    PN-E703 monitor owes their exceptionally thin profile to edge-lit LED backlighting. It is streamlined for a pleasing appearance and minimal protruding parts, making for easy placement in offices, public spaces, stores, and other commercial establishments.
  • Choice of installation mode
    PN-E703 monitors offers a choice of landscape or portrait installation, allowing customers to select the mode that best suits their display content and application. While portrait installation offers the look and impact of a poster, landscape installation puts wide images on vivid display.
  • The reliability of 24/7 operation
    Built solid and durable, PN-E703 monitor is ideal for use in 24-hour stores and in other demanding professional applications that require around-the-clock operation seven days a week.
  • Dual-screen display
    PiP (Picture-in-Picture) mode allows an AV-sourced image to be displayed within a PC-sourced one (or vice versa), whereas PbyP (Picture-by-Picture) mode puts images from AV and PC sources side by side for split-screen viewing.
  • Mirror display mode
    Mirror Display mode enables the same onscreen content to be displayed on a PN-E703 monitor. This function can be used to reinforce advertising messages in public spaces or to facilitate communications in large office or conference settings.
  • Designed for energy efficiency
    Edge-lit LED backlighting on the PN-E703 monitor helps ensure reliable performance with low power consumption.
Sharp PN-E703 70" Class (69.5" viewable) LED display
LED-backlit LCD flat panel display
Diagonal Class
70"
Diagonal Size
69.5 in
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
HDMI
HDMI Ports Qty
2 ports
LAN
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
UV²A
LCD Backlight Technology
LED backlight - edge-lit
TV Tuner
No tuner
Speaker System
2 speakers
Voltage
225 Watt
157.8 cm x 3.94 cm x 91.6 cm
43 kg
3-year warranty
225 Watt
Diagonal Class
70"
Diagonal Size
69.5 in
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
HDCP Compatible
Modes
Portrait mode, landscape mode, Mirror Display Mode
Dimensions
Without stand
157.8 cm
3.94 cm
91.6 cm
43 kg
Display
LCD Display Technology
UV²A
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Colour Depth
Up to 1.06 billion colours
Image Contrast Ratio
4000:1
Brightness
450 cd/m²
Viewing Angle
176 degrees
Viewing Angle (Vertical)
176 degrees
Pixel Pitch
0.802 x 0.802mm
Response Time
6 ms
Certified for 24/7 Continuous Operation, sync on green
Stands & Mounts
VESA Mounting Interface
200 x 200 mm
Video Features
Analogue Video Input Signals
PAL, SECAM, NTSC 3.58, NTSC4.43, PAL60
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
LAN
Connector Type
DisplayPort input - bottom , DisplayPort output - bottom , DVI-I input - bottom , DVI-D output - bottom , 2 x audio line-in - bottom , 2 x HDMI input - side , VGA input - side , Audio line-out - side , Serial input - side , Serial output - side , Network - side
Plug and Play, DDC-2B, DVI DMPM, VESA DPMS
Power supply
Nominal Voltage
Limited warranty - 3 years - on-site
20 - 80% (non-condensing)
Brand: Sharp
Price Range Ex VAT: 1500+
