Sharp LC-32HG5341K 32" Smart LED TV with Freeview
Quicklinx: DFW2WS00 Mfr#: LC-32HG5341K
  • FREEVIEW HD
  • DVB-T
The LC-32HG5341K is a HD Ready Smart LED TV with exceptional picture quality. Whether using the integrated Smart TV functions or connecting to your smart device, it's simple and fun.
With 3 HDMI ports, you can connect to your set top box, games console, Blu-Ray player or any other HDMI equipped device. Its 2 USB ports allow you to enjoy your music, movies or photos from a USB memory key or hard drive.
ACE PRO ENGINE
This powerful image optimization technology analyzes and enhances incoming video signals for accurate color reproduction, improved sharpness and reduced noise. The result is a crisp, yet natural picture.
WIRELESS TV CONNECTION
Wirelessly connect your PC or Android device to your TV and immediately send media files to the big screen. It's a great way to enjoy photos and videos together with friends and family.
AQUOS NET+
After connecting your Smart TV to your home network, you can enjoy movies and TV shows through the Netflix app or watch the latest internet videos on YouTube.
ACTIVE MOTION 200
Conventional liquid crystal displays (LCD) reproduce blurry movements. Active Motion effectively sharpens moving pictures by creating additional frames with its powerful GPU and using high-speed LCD panels.
USB PVR
Easily record your favourites programs or movies from built in digital tuners of your TV on external USB sticks or hard disk drives.
  • 3 x HDMI: Connect all your digital audio/video devices like Blu-ray players, digital set-top-boxes or advanced game consoles to your TV.
  • 2 x USB Just plug in your USB stick or hard drive and enjoy music, videos and images directly on the big TV screen.
  • 32" LED TV
  • 720p HD Ready
  • Resolution: 1366 x 768
  • Smart TV with built-in WiFI
  • ACE Pro Engine
  • Freeview HD Saorview Approved
  • SB Record
  • Miracast
  • Energy efficiency class: A+
  • Wall mountable: VESA 200 x 200
  • 1 year warranty
  • Connections 3 x HDMI 2 x USB 1 x CI slot 1 x AV input 1 x Optical audio output 1 x Mini component input 1 x M
  • DLNA
    Stream your media from DLNA compatible devices throughout the home network directly to your TV.
  • Active Motion 200
    Conventional liquid crystal displays (LCD) reproduce blurry movements. Active Motion effectively sharpens moving pictures by creating additional frames with its powerful GPU and using improved LCD panels.
  • HEVC/H.265
    With this advanced video codec your TV is ready for the broadcasting standards.
  • DTS TruSurround
    DTS creates virtual surround sound for a cinematic audio experience. Together with the built-in Harman/Kardon speaker system you will enjoy immersive sound right out of the box - no extra hardware needed.
Sharp LC-32HG5341K Aquos G5340 series - 32" LED-backlit LCD TV - HD
LED-backlit LCD TV - Smart TV
Diagonal Class
32"
Resolution
1366 x 768
Display Format
720p
Frame Rate & Enhancement Technology
Active Motion 200
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
3 ports
Wi-Fi, LAN
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
Digital TV Tuner
DVB-C, DVB-T, DVB-T2
Analogue TV Tuner
PAL, SECAM
Internet Streaming Services
Netflix
Picture Enhancements
ACE PRO Engine
Speaker System
2 speakers
Sound Effects
DTS TruSurround HD
USB
2 ports
Voltage
AC 230V (50 Hz)
Energy Class
Class F
70 Watt
Power Consumption (On mode)
31 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
45 kWh
73.22 cm x 8.4 cm x 43.68 cm
5.28 kg
Energy Class
Class F
70 Watt
31 W
31 kWh/1000h
45 kWh
Diagonal Class
32"
Series
Aquos G5340 series
TV Tuner Presence
Extended PVR
Video Interface
HDMI Ports Qty
3 ports
Modes
Hotel mode
ACE PRO Engine
Dimensions
Without stand
73.22 cm
8.4 cm
43.68 cm
5.28 kg
Display
Resolution
1366 x 768
Display Format
720p
Image Aspect Ratio
16:9
Active Motion 200
LED backlight
Dynamic Contrast Ratio
1000000:1
Time-shift
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
200 x 200 mm
TV Tuner
Analogue TV Tuner
PAL, SECAM
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
HDTV Tuner
Digital TV Service
FREEVIEW HD, SAORVIEW
MPEG Profiles and Levels
MPEG4/HEVC/H.265
Media Player
USB Port
USB Ports Qty
2
Audio System
Digital Audio Format
Dolby Digital output, Dolby Digital Plus output
Surround Mode
Sound Effects
DTS TruSurround HD
Speaker System
2 speakers
Output Power / Total
20 Watt
Audio Return Channel (ARC)
Speakers
2 x speaker - 10 Watt
Driver Details
Speaker: 2 x full-range driver
Network & Internet Multimedia
Functionality
Digital audio playback, digital photo playback, digital video playback, Internet video playback
Wi-Fi, LAN
Connect & Share
Wi-Fi Miracast
Netflix
Application Store
SHARP AQUOS NET+
DLNA
Connector Type
3 x HDMI input , 2 x USB 2.0 , Component video input , Composite video/audio input , SCART , Audio line-out / headphones , Digital audio output (optical) , LAN
CB, EMC, ERP
Power supply
Input Voltage
AC 230V (50 Hz)
0.5 Watt
Dimensions & Weight Details
Panel without stand - 73.22 cm x 8.4 cm x 43.68 cm , Panel with stand - 73.22 cm x 17.9 cm x 47.15 cm x 5.28 kg
Weight (Shipping)
7 kg
