The LC-32HG5341K is a HD Ready Smart LED TV with exceptional picture quality. Whether using the integrated Smart TV functions or connecting to your smart device, it's simple and fun.
With 3 HDMI ports, you can connect to your set top box, games console, Blu-Ray player or any other HDMI equipped device. Its 2 USB ports allow you to enjoy your music, movies or photos from a USB memory key or hard drive.
ACE PRO ENGINE
This powerful image optimization technology analyzes and enhances incoming video signals for accurate color reproduction, improved sharpness and reduced noise. The result is a crisp, yet natural picture.
WIRELESS TV CONNECTION
Wirelessly connect your PC or Android device to your TV and immediately send media files to the big screen. It's a great way to enjoy photos and videos together with friends and family.
AQUOS NET+
After connecting your Smart TV to your home network, you can enjoy movies and TV shows through the Netflix app or watch the latest internet videos on YouTube.
ACTIVE MOTION 200
Conventional liquid crystal displays (LCD) reproduce blurry movements. Active Motion effectively sharpens moving pictures by creating additional frames with its powerful GPU and using high-speed LCD panels.
USB PVR
Easily record your favourites programs or movies from built in digital tuners of your TV on external USB sticks or hard disk drives.
- 3 x HDMI: Connect all your digital audio/video devices like Blu-ray players, digital set-top-boxes or advanced game consoles to your TV.
- 2 x USB Just plug in your USB stick or hard drive and enjoy music, videos and images directly on the big TV screen.
- 32" LED TV
- 720p HD Ready
- Resolution: 1366 x 768
- Smart TV with built-in WiFI
- ACE Pro Engine
- Freeview HD Saorview Approved
- SB Record
- Miracast
- Energy efficiency class: A+
- Wall mountable: VESA 200 x 200
- 1 year warranty
- Connections 3 x HDMI 2 x USB 1 x CI slot 1 x AV input 1 x Optical audio output 1 x Mini component input 1 x M
DLNA
Stream your media from DLNA compatible devices throughout the home network directly to your TV. -
Active Motion 200
Conventional liquid crystal displays (LCD) reproduce blurry movements. Active Motion effectively sharpens moving pictures by creating additional frames with its powerful GPU and using improved LCD panels. -
HEVC/H.265
With this advanced video codec your TV is ready for the broadcasting standards. -
DTS TruSurround
DTS creates virtual surround sound for a cinematic audio experience. Together with the built-in Harman/Kardon speaker system you will enjoy immersive sound right out of the box - no extra hardware needed.
- Sharp LC-32HG5341K Aquos G5340 series - 32" LED-backlit LCD TV - HD
- Product Type
- LED-backlit LCD TV - Smart TV
- Diagonal Class
- 32"
- Resolution
- 1366 x 768
- Display Format
- 720p
- Frame Rate & Enhancement Technology
- Active Motion 200
- Video Interface
- Component, composite, HDMI, SCART
- HDMI Ports Qty
- 3 ports
- Connectivity
- Wi-Fi, LAN
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- Digital TV Tuner
- DVB-C, DVB-T, DVB-T2
- Analogue TV Tuner
- PAL, SECAM
- Internet Streaming Services
- Netflix
- Picture Enhancements
- ACE PRO Engine
- Speaker System
- 2 speakers
- Sound Effects
- DTS TruSurround HD
- USB
- 2 ports
- Voltage
- AC 230V (50 Hz)
- Energy Class
- Class F
- 70 Watt
- Power Consumption (On mode)
- 31 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 45 kWh
- Dimensions (WxDxH) - without stand
- 73.22 cm x 8.4 cm x 43.68 cm
- 5.28 kg
- Product Type
- Energy Class
- Class F
- 70 Watt
- 31 W
- Power Consumption SDR (On mode)
- 31 kWh/1000h
- 45 kWh
- Diagonal Class
- 32"
- Series
- Aquos G5340 series
- TV Tuner Presence
- Extended PVR
- Video Interface
- HDMI Ports Qty
- 3 ports
- Modes
- Hotel mode
- ACE PRO Engine
- Dimensions
- Without stand
- 73.22 cm
- 8.4 cm
- 43.68 cm
- 5.28 kg
Display
- Resolution
- 1366 x 768
- Display Format
- 720p
- 16:9
- Active Motion 200
- LED backlight
- Dynamic Contrast Ratio
- 1000000:1
- Time-shift
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Flat Panel Mount Interface
- 200 x 200 mm
TV Tuner
- Analogue TV Tuner
- PAL, SECAM
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
- Digital TV Service
- FREEVIEW HD, SAORVIEW
- MPEG Profiles and Levels
- MPEG4/HEVC/H.265
Media Player
- USB Port
- USB Ports Qty
- 2
Audio System
- Digital Audio Format
- Dolby Digital output, Dolby Digital Plus output
- Surround Mode
- Sound Effects
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Audio Return Channel (ARC)
- Speakers
- 2 x speaker - 10 Watt
- Driver Details
- Speaker: 2 x full-range driver
Network & Internet Multimedia
- Functionality
- Digital audio playback, digital photo playback, digital video playback, Internet video playback
- Connectivity
- Wi-Fi, LAN
- Connect & Share
- Wi-Fi Miracast
- Netflix
- Application Store
- SHARP AQUOS NET+
- DLNA
- Connector Type
- 3 x HDMI input , 2 x USB 2.0 , Component video input , Composite video/audio input , SCART , Audio line-out / headphones , Digital audio output (optical) , LAN
- CB, EMC, ERP
- Power Device
- Power supply
- Input Voltage
- AC 230V (50 Hz)
- 0.5 Watt
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 73.22 cm x 8.4 cm x 43.68 cm , Panel with stand - 73.22 cm x 17.9 cm x 47.15 cm x 5.28 kg
- Weight (Shipping)
- 7 kg
