Securifi Almond DSL Wi-Fi Ethernet LAN Black ALM-BLK-EU
A Router for Humans
Easy Setup Touchscreen WiFi Router.
You will be online within seconds.
Just connect your Cable/DSL modem and follow the on screen instructions.
Pre-configured security.
Prevent intruders from accessing your wireless data.
Up to 300Mbps using 802.11n MIMO tech.
Connect up to 50 users at a time.
Compatible with older 802.11bg devices.
Everything you need is just a finger tap away.
The user interface is a quantum leap over existing routers.
- Securifi Almond - wireless router - Wi-Fi - desktop
- Wireless router - 2-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Data Transfer Rate
- 300 Mbps
- MIMO technology
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Power
- AC 120/230 V
- Localisation
- Europe
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- 300 Mbps
- Encryption Algorithm
- WPA, WPA2, WEP
- MIMO technology
- Processor
- 384 MHz
- Built-in Devices
- 2.8-inch touch screen display
- WAN: 1 x 10Base-T/100Base-TX - RJ-45 , LAN: 2 x 10Base-T/100Base-TX - RJ-45
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Cables Included
- 1 x network cable
- Localisation
- Europe
