With Almond-2015 you don’t need another hub to control your smarthome devices. The smarthome hub is already built into it.
- Securifi Almond 2015 - wireless router - Wi-Fi, ZigBee - desktop
- Wireless router - 2-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, ZigBee
- Frequency Band
- 2.4 GHz
- Data Transfer Rate
- 300 Mbps
- MIMO technology, port forwarding
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP
- Power
- AC 120/230 V
- Localisation
- Europe
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- 300 Mbps
- Encryption Algorithm
- WPA, WPA2, WEP
- Built-in Devices
- 2.8-inch touch screen display
- WAN: 1 x 10Base-T/100Base-TX - RJ-45 , LAN: 2 x 10Base-T/100Base-TX - RJ-45 , USB 2.0: 1 x
Aerial
- Aerial
- Internal
- Antenna Qty
- 4
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Cables Included
- 1 x network cable
- Localisation
- Europe
