Seagate NAS 2-bay is a full-featured network storage solution offering the easiest setup and the industry's most intuitive interface. The NAS 2-bay features hardware, software and Seagate drives designed to work together seamlessly, which reduces your setup time to just a few minutes and delivers reliable performance for years to come. In addition, Seagate runs hours of extensive tests on every NAS 2-bay before it leaves manufacturing facility, to further ensure the system is running at its best.
The NAS 2-bay runs Seagate NAS OS 4 software, completely designed from the ground up to deliver ease of use, performance, reliability and a flexible platform for running add-on apps, enabling you to do more with your NAS.
Drives are the core of any high-capacity storage solution and Seagate delivers a specialized drive specifically for NAS systems. Seagate NAS HDD drives, included with the NAS 2-bay, are engineered to run 24×7 to deliver the performance needed by various business applications, yet run cooler than other drives on the market. Furthermore, NAS HDD drives are rated for higher reliability than a standard desktop drive, offering more protection for your business's critical files.
- Seagate NAS 2-Bay STCT2000200 - NAS server - 2 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 2 TB
- Installed Devices / Modules Qty
- 1 (installed) / 2 (max)
- 12 cm x 21.8 cm x 17 cm
- 1.7 kg ()
- Processor
- 1 x ARM 1.2 GHz
- Storage Controller
- RAID SATA 3Gb/s RAID RAID 0, 1, JBOD
- Hard Drive
- 1 x 2 TB SATA 3Gb/s - One-Touch Backup
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE
- RAM
- 512 MB
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- UNIX, Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6 or later, Microsoft Windows Server 2012, Microsoft Windows Vista / XP / 7 / 8
- 3-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 2 TB
- 12 cm
- 21.8 cm
- 17 cm
- 1.7 kg ()
Processor / Memory
- Processors Installed
- 1 x ARM 1.2 GHz
- Max Supported Qty
- 1
- RAM
- 512 MB DDR3
Storage Controller
- RAID
- Interface Type
- SATA 3Gb/s
- RAID Level
- RAID 0, RAID 1, JBOD
Hard Drive
- HDD - hot-swap - 3.5"
- Capacity
- 1 x 2 TB
- Interface Type
- SATA 3Gb/s
- One-Touch Backup
- S.M.A.R.T., 256-bit AES
- Data Link Protocol
- NTP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB
- Remote Management Protocol
- SNMP, HTTP, SSH
- Network Services Compatibility
- DHCP, DFS, Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), HTTP
- Wake on LAN (WOL), dynamic DNS server, IPv6 support, SSH support, static IP mode, IPv4 support, DLNA Media Server, WebDAV server, link aggregation trunking, SFTP server, Precision Time Protocol (PTP)
- Encryption Algorithm
- 256-bit AES
- UPnP
- Expansion Bays
- 2 (total) / 1 (free) x hot-swap - 3.5"
- 2 x USB 3.0 , 1 x Ethernet 1000Base-TX - RJ-45
- Cables Included
- 1 x network cable
- Security lock slot (cable lock sold separately), Mobile Transfer Protocol (MTP)
- Security Slot Type
- Kensington security slot
- IPv6 Ready
- Power Device
- External power adapter
- Voltage Required
- Power Provided
- 48 Watt
- OS Required
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 0 - 80% (non-condensing)
